EDIT.electrical//alternator change/porsche/vw
https://forums.aussieveedubbers.com/threads/104461/editelectricalalternator-changeporschevw
grogy ·
hi, i had a porsche style alternator it only had 2 wires .one larger than usual wire push on and one regular size push on. i have now changed to a standard vw alternator and it has 3 pin set up on the alternator, all regular size push on. one is dplus ,dminus,and df, marked on each pin. can anyone tell me what i need to do to wire this correctly. thanks greg... IT ALSO has a thread near the 3 pins about 8mm that obviously takes a wire with a ring connector that bolts on. it is marked b plus.
there are internal and external VW alternators
Sounds like you have the early external type
AA003 ·
B+ is the big fat red one to the battery.
D- is the brown earth to the external voltage regulator.
D+ I think is blue to the external voltage regulator and the alternator light.
DF I think is green to the external voltage regulator
Your external regulator should have the similar markings on it.
vduboy ·
AA003 wrote:B+ is the big fat red one to the battery.
+2 That is the same setup I have on my motor.
grogy ·
thanks for
that, is wiring the same with msd
