Gday all.
I was looking around the web a while back searching for info on valve spring pressure, in particular seat pressure, for basically stock VW T1s.
I found somebody's reply on here saying they use 68lbs seat pressure on their Formula Vee 1200 engines, and they run to 5500 no worries without float, and 6000 at a pinch.
Just to confirm the parts on a F.VEE 1200 though please?
31,5mm intake valve with stock OEM cam, lifters, retainers, collets and valve springs?
And the seat pressure is around the 65 - 70 lbs mark?
This is all before I start pulling the pin and ordering parts that I want for my heads. Yes, I could go all standard so everything fits together beautifully without a care in the world, or even order heads off the shelf that are WAY better than what I could do, but where's the fun in that? 馃槀
No seriously though, I'm just trying to severely minimise valve train weight (without using half the world's Titanium) as a bit of a science experiment just for stamps. It's all good fun in the end.
馃槑
modnrod 路
