bajachris88 wrote:Used black silicone sealant from mitre10 馃檪 (windscreen sealant), has worked a charm on the baja.
Be aware to not use a 'sealer'... fella at autobarn sold me that by mistake after I asked for sealant, and after all the effort of applying and bolting the body on to the pan, the shit never cured (remained a messy goo).
Thats what you want though. the factory used a non curing tar like sealer.
If you use a sealer like sikaflex which many people do, you will probably never get the body off the pan ever again.
I recently put a little on the bottom of a coil spring to stop the spring from shifting in its seat under hard cornering and I mounted a part wrong in the strut and required removing the spring again.
Lets just say it took me 4 hours to pry the spring out and clean the mess up.
馃お It was like welded in place.
imagine that over the whole surface area of the body to pan interface.
