Matching identical set of light-weight "Cheviot" alloys, 6JJ x 14. The sort with 5 oval shaped cut-outs, like on Valiant Chargers from early 70's. Quite old (poss. made 1983 if the number stamped is the date), but in excellent cond., NO cracks, chips, bends etc.. You can see why they are lighter than many alloy wheels, due to the 'hollowed out" style on the insides.
Balanced on Insides, ie. weights not attached to outer rim (to avoid chips, scratches,corrosion).
Suit 4 stud Beetle, or possibly type 3 etc... No interference with brakes, suspension on 4 stud beetle.
Includes set of 16 chromed wheel studs (14 as shown + 2 slightly different), steel washers to suit, AND 4 locking wheel studs of correct length... all in V.G. cond.
Also 4 black centre caps to fit (old, in fair cond., they fit.)
Contact by email for phone no., or by PM. (preferably!).
BRUTUS ·
more pics
BRUTUS ·
Really nice track AND/OR road tyres. Drive to the track. Drive home... No need to change wheels!
Nice light wheels to go with them. No need to repair, clean. No need to balance. No need to find hard-to-get studs or even centre caps.
BRUTUS ·
Still available. Track/Road tyres with 95%+ tread. Wheels etc. all included at no extra charge!
Boozo ·
why don't you use them? and any idea on offset, how do they sit with the guards?
BRUTUS ·
No longer required. Pic's show how they fit inside the usual old-style somewhat wider f'glass guards. [As shown, have no spacers fitted.] Have slightly more offset outwards (about 1/4 to 1/2 inch) than some other mag's, so good for beetle. [Late beetle had the greatest outwardly offset std. wheels.]
Boozo ·
rear might be ok, but front wouldnt fit under stock guards with a bit of low 🙁
BRUTUS ·
I see, yes with stock guards the old rough rule was 5-1/2" width max., front & rear; and not too wide for the tyres, eg. 185 wide was generally reckoned to be OK. It does depend on the exact offset of the wheel as well, and they all seemed to vary a bit. These seem a bit more offset out as mentioned, there is a number stamped in them, maybe that is the offset.
BRUTUS ·
Now $550 cash. You pick up.
BRUTUS ·
Now $500. You collect or arrange pick-up.
Wheels (& bolts etc.) soon available without tyres (will be sold separately or disposed of).
BRUTUS ·
Set of the 4 wheels (incl. 4 caps, 16 bolts, 4 locking studs, and washers) for $475 (The NEW price for similar wheels is $240 - $250 EACH according to tyre shop).
Set of the four tires currently included for free with the wheels, or the tires are now avail. separately, for $75 for the 4.
Cash only. Pick up only.
Pic's below shows appearance on a 1976 beetle, with flared guards. (One under hard acceleration, one under braking... must be on return road.)
esevwbits ·
hey mate, i'll grab the tyres off you for sure.
BRUTUS ·
Done. TIRES sold on 8/7/14.
The 4 rims still available(only $118.75 each, all incl.), now
BRUTUS ·
Only $115 each, or $460 for set 4 beeautiful alloy rims (set of the 4 wheels ALL incl. 4 caps, valve stems, 16 bolts, 4 extra locking studs, and all washers) . Pick-up pref.
BRUTUS ·
Given away - special door prize - to lucky buyer of another item.
Now $400 for set of 4 rims (with bolts, washers, centre caps, & locking studs).
