http://forums.aussieveedubbers.com/viewtopic.php?tid=27021
If you plan to do just one set of Heads Ian, just use a texta like Niko to mark out the flanges.
I prefer to use a dowel on the intake stud, (two nuts locked on the stud and turned to size),
and this way, you can make the port exactly the same size on both,
with the confidence that they will match time after time.
I like to bolt the assembly together and use a long shanked burr from the chamber side.
(assuming you are using tall manifolds?)
Some projects require cutting the manifold off and re-welding after you have your cross section complete.
If you choose not to make a precise fit,
as the CB stuff arrives,
you will need a smaller port in the manifold so you never get an obstruction.
To me the size of the port becomes a waste of time in that case,
especially if you have an over sized 44 valve in the first place.
Ideally the port should taper in size from the seat throat up to the carb flange.
At the very least, the cross section at the head flange should be the smallest part of the manifold.
No need to measure port volume,
just measure your work with inside calipers,
or a suitably made template.
Card board or tin, is good on a threaded stud.
