Wanting to change original 1200 36hp to later model motor.New one has 180mm fly and clutch,will this just bolt straight to existing trans or will I have to grind trans housing?
Also I could get an IRS box to couple to the new motor but would this fit straight into a '59 swing axle beetle?I dont want to go IRS suspenion though.Cheers for any thoughts.
Depends if its a 6volt 180mm flywheel or the later 12 volt 180mm used on the 1300Twin Port.......do you know which one it is ?
Is your car still 6volt ?
If its a 12volt you will need to grind the trans housing in a few spots to make it fit.
Re the IRS box, no it won't fit straight into the 59.
vwfive ·
Thanks Craig,not sure if 6v or 12v,but more thinking thats it is 12v as it is a TP.Car is converted to 12v but still running 6v starter,realise I will have to change that and bush if the fly has 130 teeth,thanks for the heads up on the IRS box and the rest of the info.
