Early 1950 alloy 25 hp engine case
https://forums.aussieveedubbers.com/threads/104977/early-1950-alloy-25-hp-engine-case
BUGBOY ·
Engine case has been cleaned check and all machining (spot facing done) ready to build. Surplus to needs as I have located an earlier case. Being an early alloy case it's perfect for a high performance 36 case as you only need to open up the barrel insert holes.
Happy to swap for early parts or POA depending if you need other engine parts etc.
