G'day!
I'm setting up end float on this new short block. Its a new CB case, new chinese cw crank, new vanadium flywheel, std oem bearings.
With no shims, i have approx 1.775mm of crank float to shim up. For 0.001 inch clearance for each shim, this equates to approximately 5 x 0.36 mm shims and 1 x 0.32 mm shim to get desired end float 馃お!
With the end float taken up, there is no binding of crank on the case inside. I really don't want to strip down the short block again after all the effort of assembly. Crankshaft engineering already did alot of work on the crank with machining bearing clearances for big ends and mains, rods, balancing, and flywheel runout issues with main seal. (On that note, they made mention that brazilian oem std vw factory bearings showed terrible inconsistencies for tolerances between the bearings).
Can I just run the shims, given there is no binding? I'm under the assumption that the excess endfloat is the result of the addition of lots of 'error' / deviation from oem specs given every component is aftermarket (dimensions of case thrust surface machining, crank, flywheel and even the oem thrust bearing). Do i need to machine the flywheel instead perhaps?
Any help / wisdom greatly appreciated.
thanks
concerned Chris 馃檨
bajachris88 路
