Multi-rib pulley for type 4 Fan/Pulley
https://forums.aussieveedubbers.com/threads/105083/multi-rib-pulley-for-type-4-fanpulley
mackaymanx ·
Been playing around with this, pulley is from a VS commodore harmonic balancer. This is just pushed together with a bit of interference at the moment, would need to be silver soldered or brazed together as the pulley is cast iron. Might see if I can chase down a steel pulley so I can get it spot welded on.
vlad01 ·
have you tried parting the balancer and using the center 3 spoke hub coupled with a center adapter, which then can bolt to the crank with the fan possibly.
otherwise there are aftermarket billet balancers for commodores.
mackaymanx ·
A centre adapter would work but I didn't want to disrupt the airflow with the spokes and hub. I'll keep looking for something more suitable, next time I'm at the wreckers.
