gt_51 ·
I read the information in Tech Talk comparing Por-15 Rust Bullet and Epoxy mastic 121. I have been using Por-15 so I bought a litre of Rust Bullet and 2.5 litres of Epoxy mastic 121, to try. If someone can help, my question is when I remove rust e.g. at the bottom of the engine lid where they all rust, I have drilled the spot welds out to remove the inner panel, cut the rust out, went through the Rust Bullet process now what happens when I weld the panel back in? All the rust prevention will be burnt off. How do you prevent this?
