Hi There. Can anyone recomend a professional mechanic in Melbourne that does Subaru into VW conversions? Just interested in chatting about installing the engine and a 5 speed subarugears box and the engineering certification required etc..?...
Would you be able to register a 3.6L motor in. Ghia?
sorenluckins ·
Good question I guess, but it's not very different output to doing a 2.5 Turbo? Any ideas on an engineer I could discuss that with?
In NSW it is VSI 06 I believe it is 3.0 X the original mass for a car up to 1100kgs.
Thanks. Any tips for Victorian regs or Victorian based engineers?
Vw nutter ·
Helbus and myself have both done suby conversions, his being a 2.2 and mine a 2ltr sti turbo into our kombis,
Pm me if you want to check out my kombi and i can show you whats involved.
sorenluckins ·
Ripper, PM sent..
Thanks.
Click on the link at the bottom of this post and I have a Suby conversion thread of what I put in my bus.
I would estimate you may end up spending tens of thousands of dollars and you would be wise to ring an engineer first to see what is required.
sorenluckins ·
The KG T34 was 880kg originally, so my engineer tells me that a 3.6 naturally aspirated isn't an issue. Which is great... Current issue is welded spindles don't make the cut and all the good A-Arm suspension have welded spindles...
That's good news about the motor sizing, must be different to NSW, it was 2.5 x forced or 3 x factory weight. I've heard that has now changed for the better.
