Best Pan base for Oval Beetle build
https://forums.aussieveedubbers.com/threads/105135/best-pan-base-for-oval-beetle-build
Mick058 ·
Hey guys,
There is probably a thread on this somewhere, but its difficult to search for 'pans'. What is the best and strongest pan to base a build on? It will need to fit with a Oval shell.
bugzla ·
1976 irs rear and h beam front just mod the rear body attachment
Mick058 ·
Can you use any year pan for this if you're going to mod the rear? And what if you wanted to do an a-arm conversion on the front - would that change the pan you start with?
Camo ·
Looks like someone may be heading back into the vw world. Can't stay away for too long 😂😂😂
Other than a strut front end, I think you can use anything. But keep in mind you will probably want IRS rear and beam front end if you are going to modify it for A-arm steering. Not sure if the A-arm mods are legal in NSW.
Kev
Hi Mick
For engineering purposes the earlier the better, so a semi auto 1500 pan or a 1500 manual pan that can be converted to IRS. The 76 pan would require compliance to later model ADRs etc.
PAZZAN ·
http://www.gumtree.com.au/s-ad/lane-cove/auto-body-parts/vw-beetle-floorpan/1011850453
http://forums.aussieveedubbers.com/viewtopic.php?tid=105131
Mick058 ·
Once bitten always bitten Kev! Yeh, I've heard the auto pans are best. Has anyone got a a-arm front end engineered in NSW? I know there are the red9 kits and Mendeola (or whoever you spell it) kits - but haven't actually seen anyone who got these engineered.
Mick058 ·
Steve, what years are the semi auto pans? late 60's for 1500 pans? Is semi auto stronger than manual pan? Whats the difference? I think the pan on my sti bug was 68 semi auto pan.
Yogie ·
The 68 and later semi auto pans have the balljoint front and IRS just like the 76 pans but without the problem of having to comply with the later ADR's.
You have to run a clutch tube though if you want to run a manuall gearbox.
Yogie
