Is a t3 cv joint and boot the same part used in a t2?
https://forums.aussieveedubbers.com/threads/105158/is-a-t3-cv-joint-and-boot-the-same-part-used-in-a-t2
pfillery ·
Some parts sites show them as the same part number. Are they directly compatible?
yes interchangeable
pfillery ·
vw54 wrote:yes interchangeable
What about the driveshaft part as a whole?
Whats the best way to store some almost new ones that have been removed (still greased but contaminated with grass/dirt from removal)? They are German made ones so I'm guessing not cheapies, would be good to keep. Should they be washed off then regreased lightly (or fully) and bagged/sealed up?
Smiley ·
T3 Drive shafts are longer.
The manual ones are about 546mm long, whereas T2 bus ones are about 476mm long.
Smiley 🙂
pfillery ·
Smiley wrote:T3 Drive shafts are longer.
Smiley 🙂
Thanks. Into the parts box with the cvs and boots then.
