FS NSW - CSP - 20.64mm Master Cylinder for 4 wheel Disc Brake Conversion
https://forums.aussieveedubbers.com/threads/105178/fs-nsw-csp-2064mm-master-cylinder-for-4-wheel-disc-brake-conversion
Pattison ·
#### S O L D ####
1300 engine (F014XXXX) 1966 to 1970.
turns over OK and flywheel end play feels good.
Would suit restoration project.
$100 ono
Located Windsor NSW
Call 0408 608 901 or PM
Rel
Pattison ·
For Sale
20.64mm dual circuit Master Cylinder for 4 wheel Disc Brake Conversion. As new condition.
Suit all type 1.
This is used as a direct bolt on replacement when converting to 4 wheel disc brakes. $200 ono
Windsor NSW 2765
PM or Call 0408 608 901
Rel
Pattison ·
ENGINE SOLD
Pattison ·
I still have the master cylinder. Is someone doing a disc brake upgrade?
silverbullet ·
is this master cylinder bigger than the standard size.
vwo60 ·
1.64mm larger inn diameter
Pattison ·
Thanks VW060
silverbullet ·
is the larger size a big improvement already have 4 wheel discs and wondering if this would improve the system thanks
Pattison ·
The larger diameter gives the system more volume.
