Aussieveedubbers 路 Tech Talk
kadron help
https://forums.aussieveedubbers.com/threads/105316/kadron-help
bugzla 路
hey guys
got some conflicting issues with these kaddies its over fueling on the progression stroke some people are saying that the squirt is to hit the centre of the butterfly and other are saying it should go to the edge of the venturi, the accelerator pump adjustment whats the right way to do the adjustment ive had a look at mr kadron but you cant read half the text any help would be great p.s it idles great and top end is spot on if you can lend me a hand it would be greatly appreciated
stevo
matberry 路
The acc. pump squirter should be aimed to shoot into hole that develops as the butterfly opens. Adjustment is so the squirter initiates at the beginning of the throttle aplication. Once the pump adjustments are set, any off idle/low speed stumble is primarily due to linkage sync. The major problem of Kaddies is the linkage. It does not grow with the motor as it changes temperature, unless you upgrade to a Berg linkage kit.
Good luck and have fun 馃檪
bugzla 路
thank buddy ill give it a go tomorrow
cheers matt
shokwave2 路
Give this a read.
http://uploading.com/med5b9f2/The-Complete-Kadron-Manual-Release-2-0-pdf
Doug Sweetman 路
Ps vacuum advance dissy helps a bunch too - if you have a 009 mechanical advance only they can develop flat spots just off idle that are very similar to over fuel
bugzla 路
ive ran 009 on another car with no problems but i see your point
tar76 路
Matt fitted a berg to my Kaddies, and have never looked back! Awesome bit of kit
Uber Kafer 路
shokwave2 wrote:Give this a read.
dont use this link. Its not a .pdf, its some other executable file. beware.
shokwave2 路
It downloads and opens up in Adobe Reader fine for me on both my iPad and laptop.
Uber Kafer 路
ok, re-phrase that, it works but its an executable file, not a .pdf. And that makes some people nervous.
As for the accelerator pump function, theres 6 pages of good info on this samba thread http://www.thesamba.com/vw/forum/viewtopic.php?p=5584944
Mr Bugget web page is poorly structured but you can copy and paste the text onto a separate word document and read it properly. Essentially he is showing how to set it for max accel pump squirt, and to reduce the squirt you wind the adjusting nut in against the spring pressure.
bugzla 路
any reason why I cant stop it from dripping from the accelerator pump nozzle from one carb any suggestions
shokwave2 路
Back off the acc pump nut a bit and it should stop dripping. Or nozzle could be bent too far down into venturi, causing the air intake to suck fuel out the nozzle.
bugzla 路
looked at the nozzle bent up alittle ill see what happens tomorrow
bugzla 路
has anybody got some good throttle bodies one has bad shaft play
