Aussie ·
What are some dizzy options for use with a stock mechanical fuel pump on a type 1? Have a Msd 6AL control box. Would like to use the msd dizzy have been told it is too wide to fit with a stock fuel pump - I am sure I have seen this done???
https://forums.aussieveedubbers.com/threads/105333/dizzy-options
Aussie ·
psimitar ·
vwo60 ·
Aussie ·
Where do you run your vac hose to? Are those Dells?vwo60 wrote:I use the Mallory vac advance distributor, has a major advantage of the MSD in the fact that it has a adjustable vacuum advance, you can change the springs as well, it works very well on my 2275
http://vwparts.aircooled.net/Mallory-Distributor-Unilite-with-Vacuum-Advance-p/4754101.htm
Another distributor that works well is a Pertronics, made in the USA and should run your ignition box, but you would have to check, I tried a fuel pump on my 2275 and it cleared the Mallory distributor with no issues.
http://vwparts.aircooled.net/Pertronix-Brand-SVDA-Distributor-12-Volt-Version-p/d186504.htm
vwo60 ·
Aussie ·
Did you also purchase the spring kit and grey spring option? The setup and accessories on this push it around $50 more than the MSD option - do you consider it worth spending the extra money?vwo60 wrote:Both webers and dellortos have a vacuum take off as standard, the MSD is only mechanical advance, the Mallory can be purchased with or without, the vacuum is a major advantage .
vwo60 ·
