donovan ·
just wondering if it is correct vw used porsche 914 brakes on the 72/3 type 3. if so what is the min rotor thickness for rwc in qld. mine are 8.5mm and 9mm
https://forums.aussieveedubbers.com/threads/105355/72-notch-rotors
donovan ·
psimitar ·
cb john ·
911, 912,and 4 cyl 914 thickness of solid front disk is 12.7 / 12.5 mm, minimum on the front is 11.0 mmdonovan wrote:just wondering if it is correct vw used porsche 914 brakes on the 72/3 type 3. if so what is the min rotor thickness for rwc in qld. mine are 8.5mm and 9mm
vlad01 ·
psimitar wrote:As for min thickness it depends on the as new thickness but 8.5 doesn't sound great. Most manufacturers allow 1-1.5mm wear.
That's what I'm running on my bug now off a 73 I parted out, havent had any clearance issues.vlad01 wrote:its the diameter you go to worry about here. the 72 up had larder diameter rotors.
278 vs 281mm
vlad01 ·
vwo60 ·
vlad01 ·
