FS CB Turbo Kit Complete $2150 ono
https://forums.aussieveedubbers.com/threads/105404/fs-cb-turbo-kit-complete-2150-ono
alansvw ·
Selling a CB Performance Blow-Through turbo kit.
Duel 45 dellortos DRLA's (turbo spec)
Turbo- schwitzer s2a (aka borg-warner) .42 a/r
Turbo exhaust system, MSD distributor set up.
Custom made tinware that lets you close decklid while running a filter much larger than that shown in photo., Distributor just been rebuilt.
This setup can be used on any VW .
Located in Sydney, will be removed from engine . can post.
..PM or call 0422 936 236 Nicholas
lovinbronx ·
Now that is cool
Dan
Allbones ·
So this is most of the parts required to complete a long block build up yeah?
Ollie ·
Allbones yeah I think thats right.
This set up makes one HELL of a sounds - what dreams are made of!
Allbones ·
I want to so bad, but then I have to put a gearbox to take it behind it aswell, ahahaha.
Boozo ·
bah just be easy on the clutch.
What about the carby needs rebuilding?
alansvw ·
The Right Carb had water in it. This was due to a open/raised deck-lid.
It has been pulled apart but now need to be assembled
alansvw ·
Just to clarify:
The sale includes:
- CB performance hide-away turbo kit
- dual carbs 45 dels - fully setup for turbo application
- Manifolds and linkage with the (turbo covers)
- full turbo and exhaust system
- MSD 6AL distributor
- Custom built tinware
This system is designed to fit under the deck-lid
turboty ·
Nice... how much for the whole motor set up...?
alansvw ·
You could buy the whole car for $22,000, It has absolutely everything imaginable done and done properly over $50,000 spent on it over 15years, Would swap for a Kombi.
alansvw ·
some more info on Turbo system and photos pf exhaust.
Blow Through Schwitzer T-3 turbo & adjustable wastegate, Dual Dellorto 45 DRLA carbs modified for blow through turbo
Exhaust - CB performance with O2 sensor, jet hot coated, MSD Billet Distributor PN8485
alansvw ·
Up-date. .. . a number of people that enquired ,rang or sent me a PM were concerened about the cost to assemlble the cardby so I have had Adrian at POWERTUNE reassemble it, so all doneand ready to go!
alansvw ·
For sale complete CD Blow through Turbo System. Includes it all... Manifolds, linkage, Webers, Exhaust, Custom Tinware, MSD complete system and the turbo. Ready to instal and enjoy. $2300. located in Manly
txt Nicholas 0422 936 236 or send PM
radojkie ·
Hi.......you mentioned whole car for sale. can you please include some pics of the car
empi ·
Hi will the dry sump and the J tubes be included? is this kit ready to bolt on and go?
alansvw ·
sorry rado, Car is being kept for now.
Empi the j-tubes are included. Im not sure what a dry sump is. However i know the kit can fit all busses, ghias, beetles.
Anyone can fit it- just need tuning with MSD and fuel lines connected etc
alansvw ·
One of the best sounding and running turbo kits available for Dubs. Great for either a street car, project or even a drag machine!
empi ·
In the photo of the under side of the engine, the sump has a pipe to the turbo i assume lubricating the turbo?? (Possibly says Claude Buggies on the sump plate)
kimmeh87 ·
Keen as. Contacted you via text
Performance Upholstery ·
That's a deep sump with what looks to be the turbo oil drain into it... The turbo is lubricated by somewhere there is oil pressure.
empi ·
Ok so is deep sump included?
empi ·
PM Sent
alansvw ·
Price Drop $2200.
System can be sold separate without the MSD ignition system. All boxed and can be shipped interstate.
PM me for questions etc
Boozo ·
what size engine was this on? and how soon did it see boost?
Ollie ·
It's was on a 2276! Can't remember when the boost came in sorry!
alansvw ·
yeah ^^2276cc and boost was 3000RPM onwards🙂 hell of a ride
alansvw ·
Need it SOLD to move on to new project so open to offers over $2000.
snowman9 ·
Have the Dells been correctly turbo prepped?
ie: turbo seals on the inner throttle shafts. Neoprene top gaskets, larger needles & seats with viton seal & heavier spring on the needle.
What boost pressures have they been run to?
Also, I can't see an adjustable wastegate in your pics.
Does your setup come with fuel press reg. and associated fittings?
alansvw ·
The Dels are fully setup for turbo and only run to 9 lbs on a very cold day. The setup was for 6-7psi. The waste-gate is adjustable and connects off the exhaust. A simple Turn of a screw lets for more boost if needed. My engine was high comp so i didnt/couldnt run too much boost.
This is 100% complete and just needs to be installed/fitted.
Thanks for all the offer and interest guys
alansvw ·
Price reduced to $2150 ONO.
salty072 ·
Pmd
alansvw ·
Salty have sent you a PM
