Biting the bullet here. Taken out my EA81 and SPFI system. Purchased a 38/38 weber carbie synchronic. Going for a full reco.
While I'm at it I have never been completely happey with the now very old VW type 3 full auto trans in terms of operation. By the way a Subie auto will not fit- too long. Besides am happy with the VW.
What are the things to looks for when inspecting this auto unit and the mods to do?
The auto has had one nagging issue that being when changing from first to second if too much throttle used it can easily over rev.
The torque converter has never been touched. How can it be checked? what are the signs of problems? is it worth taking it to a auto specialist with the auto trans for checking?
Finally, I am considering extending the auto kickdown modulator vacuum hose to go more towards the driver so the driver can adjust it on the run. A small air adjuster would be sought to do this rather than getting under the trike to adjudt the standard mudulator.
I am aware of the critical mod of installing two seals instead of one between the auto and the axle. Are there any other changes? What measures can I take to stop oil leakage? A 'O' ring was recently replaced on the ip stick tube somewhere, by a mechanic.
The axle has no issues excpet the two seal at the CV's which I have and will be replaced.
I'm posting this as I dont want to repeat the drivetrain extraction ever again!! Hope you guys have some ideas
tweety ·
