Got the bug on the road finally. Drove it today and it will accelerate initially but won't rev at all. It feels as though it's starving when I try to rev it but will run if I pump the accelerator pedal (do they have an accelerator pump?). Any suggestions where to start? Maybe even fuel pump?
barls ·
Check you fuel filter
Dazz ·
Fuel filter is clear but will replace it anyway
Solenoid cut off not connected?
Idle jet blocked ?
Dazz ·
Update, it just died on the road today. Cut out and wouldn't fire back up. Tow truck home and it fired straight up in the garage. Is there a strainer in the float bowl that could be blocked? Seems funny how a trip home may have losened some blockage up?
Anthiron ·
- Fuel pump diaphram ok? Maybe take the line off at the carby end and disconnect the coil. Turn the engine over by hand a couple of times to see that fuel pulses out of the line.
- Drain the float bowl and remove the main jet to see if its clogged
- leave the ignition on but dont start the car. take the power wire off the cut off solinoid and just tap it on the terminal. You should hear a click as the solinoid engages
- Unscrew the solenoid and check that the jet is clear
- to check the air correction jet you will need to take the top off the carby so I would try the other stuff first. but once you remove the top you will see the jet to check.
Yes there is an accelerator pump but it sounds like yours is functioning.
something Odd that I have found before to check.......is the fuel spout even there? Should be a little brass tube bent around to squirt fuel down the throat of the carby.
mgiles ·
Sure its not flooding? Which is why you could start it a little while later?
bajachris88 ·
Whats the engine / carb?
if its a dual port 1600 with stock manifold, check boots for cracks (on manifold), or pipes on manifold / carb that aren't blocked off.
I'm thinking vacuum leak.
The pump of the accelerator provides the initial fuel squirt to satisfy initial acceleration, and the throttle butterfly closed at idle provides just enough vacuum to obviously maintain idle fuel delivery, but as soon as you open that butterfly and fuel pump finishes what its doing, it then starves (by the sounds).
Your ability to not restart again can support this. Warm engine restart means the choke will most likely be open (not closed like a cold start), reducing 'vacuum' pressure in manifold.
Dazz ·
Fuel solenoid definitely clicking when tapping connector on and off terminal.
Fuel pump pulsing and squirting fuel into a catch bottle.
It seems to get progressively worse the longer it's driven so maybe there is some scale or shit in the bowl that is blocking a jet progressively as I drive along.
It's a 1600 twin port with stock superbug carb so am I right in saying its a 34 pict?
Anthiron ·
It will say what kind of Solex it is on the side of the carb.
But yes a stock super would have a 34.
when the engine is warm and you take off the air cleaner is the choke open or closed?
Dazz ·
Choke is open when hot. Just drained float bowl twice and there is a shit load of fine dust, and small flakes of scale in it. Anyone know of someone on the nsw central coast that has carby kits?
Anthiron ·
Mick Motors or ClassicVeeDub via snail mail is your best bet. Mick motors would have it to you in 2 days.
Dazz ·
Classic vw has a brand new solex 34 pict listed for $140. Hardly worth rebuilding 1 at that price
Anthiron ·
If your origonal German Carb is still in decent shape then I would rather an OG Carb than a Brazillian or Mexican remake any day.
Dazz ·
Very good point
kylandpl ·
Sorry, you have probably solved this issue by now, but if you still need a carby rebuild kit, try:
