BRAKES/RIMS/CARBS/STUFF
https://forums.aussieveedubbers.com/threads/105532/brakesrimscarbsstuff
scot70wagon ·
* Front and rear disc brake set NEW. Cross drilled rotors front a nd rear, rear calipers and fitting kit, handbrake cables. Surplus to needs this kit came from classic and is the dual CHEV AND PORSCHE PATTERN kit. good brakes $700
* Just removed 40dcn PAIR weber carb set(duals) on gene berg manifolds with the shroud mounted extra heavy duty linkage. comes complete ready for beetle (as removed)or change linkage for type 3. Have gone injection only reason for sale. On a 1916 and ran beautifully. $800
* Porsche Polished 928 Wheels , Polished caps included 4 of 16 x 7 inch alloys. Perfect for type 3 or beetle and have seen them on the odd kombi as wel $400
* Early beetle alloy under dash guage holder. Holds 2 gauges $75
* Late type 3 front 3 point seats , nice and clean in grey . Have been retrimmed along the way. $180
* Wood rimmed three spoke steering wheel, often referred to as max robb wheel. has boss kit fitted in good condition $180
* Flat 4 wood 3 spoke wheel(same as empi gtv wheel) I n good condition. $250
* Porsche cookie cutters in 15 x 6 and 15 x 7 2 of each with tyres $300
* type 3 exhausts. monza 4 type and empi quiet pack style in steel. both new just sitting around gathering surface rust. ........Both gone
* Beetle swing axle KMAC rear sway bar/ compensator with fitting kit $120
* beetle swing axle rear sway bars(blue Selby maybe). I have 2 $ 95 each with fittings
* Beetle or type 3 retro black steering wheel with chrome horn ring and button. Has only been removed from box and trial fitted. $150
All parts in Newcastle contact on 0414 881 084
donovan ·
pm sent re quiet pack exhaust
66doubledoor ·
would you sell just the rear disc setup ?I think you could sell the front fairly easily ,I have fronts on my bus and have a 71 swing box rear thanks
scot70wagon ·
66 DOUBLE DOOR . GIVE ME A SHOUT.
beatman11 ·
Do you have some pics of the steering wheels?
turboty ·
Still have the complete brake setup? Is it a bolt on deal... ie has everything needed... what bugs will it fit?
scot70wagon ·
Beatman shoot me your number and can shoot some pics off.
scot70wagon ·
Brakes are a universal fit.
turboty ·
Message sent about brakes
