Aussieveedubbers 路 Tech Talk
upright into a late model bay window kombi
https://forums.aussieveedubbers.com/threads/105574/upright-into-a-late-model-bay-window-kombi
binner 路
errrrr, what or if any mods need to be done to throw a upright into a late model kombi do you need to do? Am I close on the below
tinware
馃槑
thanks in advance
binner
matberry 路
Depends on the bay, 2 litre or not, for bell housing and starter change, also gear ratio issues for a stock 1600. Otherwise it's a bolt-in with the right tin/engine support bar
binner 路
oops, i forgot about the moustache bar. If its a 2ltr original that means i need a starter with the longer shaft and bell right?
or can i shave down the shaft and use the same box/bell housing
I will add ive had a few beers tonight so not thinking straight.....馃槀
matberry 路
If 2 litre, to make it bolt up you'd change starter, bell and input shaft. But the ratios would not be kind to a stocker
