Aussieveedubbers 路 Tech Talk
trakka conversion water tank as a hole
https://forums.aussieveedubbers.com/threads/105580/trakka-conversion-water-tank-as-a-hole
leogroover 路
Has anyone had a hole in their water holding tank? What did you use to patch it up?
pfillery 路
With a stick dear Henry dear Henry, a stick馃榾
Is it steel or plastic?
leogroover 路
I don't know what is made of
donn 路
How big is the hole, is there any way you can get at the hole from inside the tank?
pfillery 路
Could be welded or soldered if metal (lead free solder of course) or plastic welded for a plastic tank.
For a quick emergency fix either gaffer tape or fabric impregnated with epoxy glue like araldite.
Easier to fix than a fuel tank. No kaboom.
