Aussieveedubbers 路 Buying, Selling & Swapping Parts
Big Type 1 engine and close ratio gearbox 4 sale
https://forums.aussieveedubbers.com/threads/105583/big-type-1-engine-and-close-ratio-gearbox-4-sale
Menangler 路
I have decided to sell the engine and gearbox from my '69 Beetle.
It is a 2386cc 86 x 94 CB high roof, thick deck alloy case, 86mm E4340 chrommolly forged crankshaft with new AA 200mm flywheel,
5.6 CB H beam rods with 3/4 ARPM rod bolts,
30mm fill flow oil pump with Berg relief pump cover,
Engle FK87 cam, Scat lifters,
A/C net heavy duty aluminium push rods,
Jaycee push rod tubes,
CB 1.4 ratio rockers,
Mahle 94mm piston and barrels,
CB CNC Oval port heads with 42 x 37.5 valves,
comp is 9.2 to 1, heads have 63cc chambers with 1.25mm deck.
Engine is running 45 DRLA dellorto carbs on CNC straight IDF manifolds with a CB cross bar linkage and air cleaners,
ignition is a Pertronix billet dizzy, MSD wires.
Engine comes with tinware, generator, stainless steel merged exhaust with stinger,
stage 3 Kennedy clutch,
2 x Jaycee alloy pulleys, a stock size and a power pulley for racing.
Engine has run twice at Eastern creek, once at Warwick and has been driven less than 200 K's on the street.
Gearbox is a fresh Shimo built swinger, with HD fully polished Berg axles and early narrow axle tubes, it has a 4.125 ring and pinion, Kombi course cut 1st and 2nd gear and close ratio 3rd and 4th, alloy spool, heavy duty steel side cover, all new syncros, new pinion bearing, gearbox is 2 race meets old.
This combo ran 13.1 @100mph at Eastern Creek in Febuary.
Prices,
Engine .$Sold
Gearbox $Sold
Phone Dave 0402 003965
Located in Nowra NSW 2541
cnfabo 路
Someone grab a good deal 馃檪.......
benny_acko 路
How much is a kidney worth these days?
waltermitty 路
Not as much as your finely tuned and original sense of humour.
Mitchell
Allbones 路
Do you accept first borns?
Squidy 路
Hmmmmmm tempting
Governor 路
Bargain
Now there is no way this will still be available in 6 months when I will be in the market for my next engine
Menangler 路
Sold.
scot70wagon 路
Engine is available again due to it not suiting the desired application. Is now in newcastle and is for sale for $6700 .if interested call me on 0414 881 084
matberry 路
Ha....Too fast for you Scott?
馃槀馃槀
Craig Torrens 路
matberry wrote:Ha....Too fast for you Scott?
馃槀馃槀
馃槀馃槀
Squidy 路
Just drop it off at mine 馃槈 got a stroker I can swap ya !
hrastovica 路
If i win the lotto tonight be expecting a call in the morning 馃檪
DDWR450F 路
Hi Scott
I'm thinking it would be a great upgrade for my new buggy!
But I'm not sure the wife will think so......... I'll put some ground work in
and see what i can do!!
DDWR450F 路
Hi Scott
PM sent mate.
scot70wagon 路
none received.
DDWR450F 路
PM sent this time!
