Hi guys,I have noticed my lower ball joints are floppy jaloopy and have been in the car for maybe two years.its got me stumped why they are stuffed already..I thought they should have lasted a lot longer then this...do I need the longer travel ones or std type..
Fabo
HappyDaze 路
You may have to up-grade to K&L, Chris. 馃槒
Craig Torrens 路
Wow, mine are still good after 15 years of racing.
Were they put in the correct way with the gaps in ball joint lining up with marks on the arms ?
Did you setup the front suspension so the ball joints weren't at the end of their travel at full suspension compression ?
What brand of ball joint did you use ?
cnfabo 路
HappyDaze wrote:You may have to up-grade to K&L, Chris. 馃槒
Nnooooooooooooooooooo!!!!!!!!l what u talking about,I seem to have seen the no#8 has hiem joint/no longer swing axle,lol馃槀
cnfabo 路
Craig Torrens wrote:Wow, mine are still good after 15 years of racing.
Were they put in the correct way with the gaps in ball joint lining up with marks on the arms ? Not sure but the they move forward and back 90 to the tube on the trailing arms
Did you setup the front suspension so the ball joints weren't at the end of their travel at full suspension compression ? Shop just pressed them in.did not know that u can press them in any different angle...I'll go have a looksie...
What brand of ball joint did you use ? Would not have a clue..
Fabo...
matberry 路
If aligned properly, as Craig said, they should last for years. Quality of the joint is my opinion. Even some German joints are crap. I use specifically Febi with gold anodising, the silver cad plated ones can cause issues even though branded Febi.
matberry 路
Also on B/J front ends, the shock length and suspension height/bumpstop arrangement is imperitive for handling AND longevity
HappyDaze 路
Half right, Chris....I've replaced the link pins with rod-ends [to give camber adjustment], but the rear end is definately swing-axle.
cnfabo 路
matberry wrote:Also on B/J front ends, the shock length and suspension height/bumpstop arrangement is imperitive for handling AND longevity
I think I must of got crap ones also..where do I buy the good ones
cnfabo 路
Half right, Chris....I've replaced the link pins with rod-ends [to give camber adjustment], but the rear end is definately swing-axle...its a funny hump day today馃槀
matberry 路
Vintage Vee Dub Supplies 02 97891777
PAZZAN 路
yep馃憤 swing axle that dosn't swing any more馃憤
HappyDaze 路
cnfabo wrote:...its a funny hump day today馃槀
.[/b]
[/quote]
No idea what you mean...馃檯
HappyDaze 路
PAZZAN wrote:yep馃憤 swing axle that dosn't swing any more馃憤
