Good afternoon!
Would anyone know if a 76' model bug steering column be interchangable with a 69' 1500 series bug?
I understand they have same chassis and dash, however different steering wheels and indicator stalks. I wish to use the original indicator stalk, and steering wheel, but just swap the internal collapsible steering shaft.
I suspect the one i have is a bit dodgey at the clamp where it sleeves onto the metal coupler (at the rubber steering coupler). despite the tightness of the bolt/nut, theres probably +/- 20 deg movement if you hook it hard enough to rotate left/right (hence I know its not steering box slop, and visually i have witnessed it rotating about previously).
I suspect the 215's have given it a hard time.
thanks,
Chris.
bajachris88 ·
