Gday All,
Have done a engine rebuild and now the god dame engine cam plug has a small leak. New rear main fitted and its defiantly the cam plug. Use some dye and uv light to prove once apart...
Rebuilt with a new plug but the cam gear shat it self and had to split again. So used the old new metal plug. Engine has done now about 20kms if that.
So the rubber plug thats available has any one has some good, bad stories theyd like to share.
I really dont want to split the case again. Just loosing the rebuild a engine mojo and really want to drive it.
Used a brand spanking new bubble top case so no issues with it.
Cheers Uncle Baz
Uncle Barry ·
well looks like no one has any horror stories. Ill give it a go.
The rubber plug is designed to fit a case that has no groove. The metal plug is for a grooved case. I've not tried fitting the rubber plug to a grooved case but I think removing the old one without hurting the sealing area may be difficult. Sometimes I've seen the bearings and/or sealant block the drain channel to create a leak, or when you had it apart to do the cam gear, the surfaces got oiled and didn't seal properly??
Uncle Barry ·
yeah the rubber plug suppliers say it can be used for both. Would have to use some premium sealant for sure. But splitting the case again would just be the straw the broke the camels back. it would be a fire sale of car, and we have worked so hard to this point to do that and not get any enjoyment out of the car. Id be prepared to give it a go with the knowledge of splitting the case in a few years. I could live with that. Interesting that not more stories of cam plug leaks.
cheers.🙂
shokwave2 ·
If it was me and it was a small leak, i'd drain the oil, clean the area and smear with the black Permatex sealant and let dry for a few days. Save you from splitting the case. If it leaks again you have bigger issues.
