Aussieveedubbers · Bugs
This weekend is it, we start
https://forums.aussieveedubbers.com/threads/105933/this-weekend-is-it-we-start
tan36 ·
Today I'm off to buy some tools from a list I made off the forum of what I will need to start, ( already have a few bits so not to big of a list for now)
Tomorrow we plan to strip out the fuel tank, and wires (must remember to take lots if photos ), then remove doors, windows and both hoods.
Sunday starts body removal. Fingers crossed for good weather to work in.
So what I want to know is any hints or tips that I might need to know for any of these jobs, also any must do!!!!! Jobs in case I haven't found that info yet.
TIA Tan
Deadpan ·
One tip I will start with-have plenty of different size resealable bags,disposable food,ice cream containers and permanent marker to put all bolts,screws and bits and pieces and mark them on dismantle
57 oval ·
Tan
You will be surprised how fast it will come to pieces, once you get started you wont want to stop.
best advice as above bag and tag all parts and keep every bit of rubber, seal grommets everything it all helps when you go out to get the replacement ones, good luck champ
bajachris88 ·
And definitely understand that in vehicular restos, it will always look worse before it gets better. It can be demotivating after disassembly to see a million separated parts and the heap of work left to put it all abck together restored, particularly when it starts as an assembled or near assembled project. Just got to remember its part of the process.
Another good tip is how to deal with the worst / most challenging bolts teh car has to over, which is the door hinge philips head drive bolts in my opinion. Plenty of penetrating fluid, plenty of recoats, a 1/2inch drive philips head tool and a breaker bar, but be sure to use the hammer to 'knock' the philips drive piece in to 'crack' the threads loose.
IF you got A pillars to replace, befoer cutting out the old rusty a pillar or removing the body off the pan, weld supporting steel bar to 'hold' the right shape and position of the dash. Cutting the a pillar out without supporting the dash will lead to the dash saggin ever so slightly under weight. You won't notice it by eye, but will when you reweld in an a pillar and try to close a door.
tan36 ·
Thanks everyone.
Bajachris88 I know of the bracing across the doors for heating channels, where else do you mean for the dash?
Today I got the bonnet hood off, fuel tank out and labeled and drew out pics about 3/4 of the wiring under there OMG it's a mess LOL.
xerxes ·
Good luck Tan
haven't got any advice yet but will keep an eye on your thread for tips and tricks when i take mine apart - sooo got itchy fingers to get on with it 🤪
vduboy ·
bajachris88 wrote:And definitely understand that in vehicular restos, it will always look worse before it gets better. It can be demotivating after disassembly to see a million separated parts and the heap of work left to put it all abck together restored, particularly when it starts as an assembled or near assembled project. Just got to remember its part of the process.
x2 Very good advice there, It can definitely be depressing at times looking at a rusty bare pan where a complete car once sat but it will be worthwhile when you get to drive it again. Don't throw anything out however shitty it looks as you'd be surprised how often you need that thingymajigdoodad that is nla. And take more photos than you think are neccesary, it has helped me with mine massively. Good luck!
