Hi everyone, finished removing most of the wiring under the bonnet today, but can not work out how to remove the switches inside the car. Eg hazard lights, wipers etc. they are the pull out push in ones 1970 beetle. Thanks 馃檪
barls 路
depending on the switch the knob screws off then there is a nut that requires it to be unscrewed using ether the proper tool or a pair of needle nose pliers and then they just pop out.
the different ones are the fresh air box ones they just pull off.
tan36 路
Thanks, mine where stuck up really really tight so where not screwing the top part off so that had me at a loss, but got that bit off will have a go at other part with the needle nose tomorrow.
