So my 1600 kombi engine stopped last week. Symptoms were just like when you turn the fuel off on the old lawn mowers and let them run dry. I knew I had plenty in the tank but went through everything ignition related and all checked out ok. So on to the fuel side. Minimal fuel in the lines and not much coming out when engine cranked over. I primed it using a fuel bulb and it fired up immediately. Hence my assumption the fuel pump is dickey.
Several questions.
I'm running twin kadrons. Is the stock style pump enough or should I be upgrading to electric straight up?
I see 2 styles of pump, one listed as being for generator models and one for alternator models. What's the difference? Is it simply pipe placement or something else?
The pushrod that operates the pump is supposed to have a max height of 13mm but mine seems to be half that. The book says you add or remove gaskets to get it right but there certainly aren't 6mm of gaskets there and the rod doesn't look appreciably worn. Is the quoted figure right and if so what would cause mine to come up short? Wrong rod?
Should I just go electric to start with?
pfillery ·
