Aussieveedubbers · Bugs
Acceleration problem
https://forums.aussieveedubbers.com/threads/106088/acceleration-problem
lenny1870 ·
When taking off, the engine stutters and misses and I can't accelerate very well. I have trouble going up inclines, let alone hills and I don't know what the problem is.
I have cleaned out all the jets in the carburettor (30 pict-2) and there is enough fuel reaching it....the timing is set to 7.5 dg before tdc and the points gap is 0.4mm. I thought maybe the squirt may have been a problem, if there was not enough? But I am not sure?
I have a Bosch 0231 127 009 distributor also
Josh
barls ·
whats your points like?
last time they were adjusted?
lenny1870 ·
barls wrote:whats your points like?
The points were adjusted this morning and there was a small improvement although the acceleration problem persists :/
has this only just started?
Shuffs ·
More questions!
Is the miss,just like it's dropping a cylinder,or is the whole engine dying?
If it's not a fuel problem,and you have the points sorted,maybe it could be a plug lead,the plugs themselves,main lead from the coil,or the coil itself.If you have spares of these,I would try the easy changes first (leads and coil),but don't do the lot at once and try it,because if that fixes it,you'll never know what was at fault.
lenny1870 ·
I advanced the timing by 5dg and there was a significant improvement although I'm not convinced I have fixed the problem..I took it for a test drive up the main hills I drive and it went fine. My worry is wether or not the advance in the timing will effect anything?? Aka create more problems from now on??
And yeah this problem only started last week...
plimthing ·
I had this on my SB. I know you said you checked the squirt for quantity but is the nozzle still there and if so is it pointing down the centre and not aimin at the sides of the carb throat?? Mine had gone completley (|!?) and the car would just stumble on the slightest acceleration.
Camo ·
Replace the condensor.
Kev
bajachris88 ·
so you have a 009 dissy you say.
well... firstly you need to time the dissy differently to the stock vac style distributors. You need to adjust it so the maximum advance is around 32 to 34 degrees. What ever it rests back down on at idle (be 7.5 deg or otherwise) is what it will rest down on. With 009's you set the max advance limit to 'tune' the timing.
Weak spark can also cause issue. Ensure gap is not too large. Not sure on your level of experience, but remember never remove spark plugs on a hot motor or you will damage the head threads.
With accelerator pump, easiest way to check is to turn the throttle ever so small and you should see at least a drap going in. IF you are turning the throttle 30 deg or so before it spits out then it ain't right.
Lastly, i had a vac dissy go out similiar to the way you describe. Backfiring and carrying on. I'm not sure what the issue was but i just swapped out to a wannabe 009 dissy. Ensure all mech advance mechanisms in the guts of your dissy and move around and spring back freely, and its cheap insurance to swap the condenser.
landfall ·
Do you have a tachometer?
If so, at idle, remove one spark plug lead at a time and note the drop in RPM. If there is a significant difference in any one cylinder, then first up check the spark plug lead, ie: the faulty cylinder will not drop the RPM as much as the good ones.
You can check each lead with a multimeter set in the Ohms category 200k.
If the lead checls out OK, just to be on the sure side, check the distributor cap for any cracks or arcing.
If all this is OK, then you are left with a compression test on the cylinder that is not performing.
Ken
oldturtle22 ·
Check to see if the advance mechanism in the dizzy isn't seized or beginning to seize.
