WTD - SYD 1500 gearbox
https://forums.aussieveedubbers.com/threads/106159/wtd-syd-1500-gearbox
DubbinDan ·
Looking for a 1500 gear box..
Dan
0414 901 008
grumble ·
Dan I have a transmission out of a 74 beetle complete drum to drum it is in Taree,pm if interested.
petemart ·
grumble wrote:Dan I have a transmission out of a 74 beetle complete drum to drum it is in Taree,pm if interested.
Is it 100% functioning, no popping out of gears and syncro into 2nd still half ok?
What is the number on it?
He needs the one with 0.89 4th with a 3.875 r/p not the late 1300 one that went back to the early 1300 gearing
DubbinDan ·
Thanks Grumble. PM sent.
Pete, 1500 box had the 4.125 diff ratio 👍
petemart ·
Craig Torrens wrote:Pete, 1500 box had the 4.125 diff ratio 👍
Yep the 1500's are 4.125, but if it's a real late 74 swinger didnt they have the 3.88 or did they all go back to 4.3 diff with the twin heat riser 1300 twinports??
74 swinger (1300 Twinport) has a 4.375 Diff ratio.
DubbinDan ·
Thanks Craig and Pete. Box sounds good grumpy..
Old Hutcho ·
Grumpy?
petemart ·
DubbinDan wrote:Thanks Craig and Pete. Box sounds good grumpy..
The dudes name is Grumble Dan.. 🙂
It's no good for the 1916cc as if it's the late box with the early gear ratios so will rev its ring out on the highway..
It will raise the revs by around 5-6%.........so if you were cruising at 3000rpm with a 4.125, it would increase to 3150rpm with the 4.375. The 4.375 will give better acceleration for around town. 👍
grumble ·
Hi Dubbin no message received,Pete I drove the car for a total of approx 500 metres and it functioned ok,didn't jump out of any gears and I didn't hear any clashing of gears. I don't know the box No as I am not home at the moment.The box is for sale as is.
