reversed coolant manifold
https://forums.aussieveedubbers.com/threads/106207/reversed-coolant-manifold
farquire ·
anyone in australia doing a reversed coolant manifold for a suby
farquire ·
anyone had any experience with not reversing the manifold ,small car have a kit for this but wondering why everyone seems so keen to reverse the manifold,also who to go to for the harness mod its going into a 90 syncro ,have a 2003 liberty 2.5 and pulled the harness out yesterday,sooo much wire
Camo ·
Hi there,
I can't help you, but have a look over this (long) post. I think from memory there is something in it about reversing the manifold.
http://forums.aussieveedubbers.com/viewtopic.php?tid=67295&page=1
Kev
mackaymanx ·
I had my manifolds done locally, I did all the prep work and dropped them off to be welded. I'm putting an EJ 25 in my syncro and using the smallcar coolant pipe which used the standard coolant manifold.
Lovebuggy ·
AMAuto is your place - on the sunshine coast.
http://www.amauto.com.au
Send them your loom and they will strip it out and send it back.
MickH ·
I run my T3 Caravelle with a standard coolant manifold (not reversed) and an EJ22..
farquire ·
so reversing the manifold really only makes the plumbing more direct or neater ,the stainless pipes from small car must run around the top of the engine and back down the side, anyone got a picture of this,also re the harness there's a guy on ebay doing harness's, luke from bayside motor garage moorabbin anybody used him or know his work
mackaymanx ·
This is not the best photo but these pipes are usually fitted to the turbo and H6 conversions.
nils ·
farquire wrote:so reversing the manifold really only makes the plumbing more direct or neater ,the stainless pipes from small car must run around the top of the engine and back down the side, anyone got a picture of this,also re the harness there's a guy on ebay doing harness's, luke from bayside motor garage moorabbin anybody used him or know his work
If it's the add I am thinking of, the picture is actually of my harness 😀
. Go figure
Shame you are not looking for a EJ22 harness, I'm thinking of trading mine for an unmolested one and starting again.
farquire ·
i'll take that as a negetive thanks ,pipes look pretty neat may go that way
mike
mackaymanx ·
Here are some quick shots in my engine bay, the brackets on the pipe don't really line up very well. Holes will need to be drilled and brackets bent/adjusted.
farquire ·
thanks, pipes look like they'll do the job and be neat,motor i've bought is out of a auto,so i'm after a flywheel,was given a old wrx flywheel with the engine ,don't know what year ,is this useable if not what is, using smallcar bellhousing.
mackaymanx ·
Think you will need a NA flywheel, the turbo flywheels have a different height.
farquire ·
the one i have is 25 mm thick overall dia 315 mm machined face/ pressure plate face outside dia 290 mm by inside dia 145 mm recess looks about 12 mm any chance of checking the sizes against yours
mackaymanx ·
Ring gear is in the same position relative to the mounting flange of the flywheel.
NA is on the left, turbo on the right.
Given that the SmallCar conversion has trouble with the over extension of the clutch slave cylinder, using a flywheel which make this worse is not ideal.
farquire ·
looking at those i'd say mine is a turbo thanks for your help
silverbullet ·
I have done mine myself. just had to strip everything of the engine and cut and shut the pipe and get it tig welded back together seem to work well. only cut around 1 1/2 inches out of the middle of manifold between last outlet and the end. and blocked the other end up where the 1/2 inch pipe comes out.
farquire ·
been awhile but have now fitted a 2003 2.5 using smallcar components and a non reversed manifold,up to the stage of running fuel lines and fitting the harness ,the subi motor has three lines, fuel in, fuel return and an evaporative line,wondering where the evap line goes,had my harness done by am auto and wondering which parts of the immobilizer i need to keep,also what coolant to put in always used the blue g11 in the vw motor
vlad01 ·
has a purge solenoid yeah? you will need a charcoal canister if thats the case.
farquire ·
have the original t3 cannister so the evap line just plumbs into that ?
vlad01 ·
farquire wrote:have the original t3 cannister so the evap line just plumbs into that ?
depends on the canister. being old I seen more have a purge valve operated by a vac port on the TB just past idle.
Probably need a canister from a car that uses a solenoid.
basically they have 3 ports.
Evap/vapor= from the fuel tank vapor line
Air= just to atmosphere or better in to the air cleaner box to prevent dust ingestion.
Purge= to solenoid operated by the ECU. this is condensed liquid fuel.
mackaymanx ·
Here is a new product from SmallCar that I'm trying out, cast reversed coolant manifold.
Bleed off fittings to thermostat
Sensors
Piping to header tank, T piece has reducer built in.
nils ·
Nice,, I'm interested to see how that shapes. Up
mackaymanx ·
Cleaned up the manifold a little today and gave it a pressure test. Started at 10 psi and finished with a max of 25 psi, no leaks.
