So I have a hot drum, but I'm not sure what is causing it.
Car is a 1964, but I believe it has a later model swing axle.
I do have the car dumped two splines on the outer.
The indicator was the car burning through brake fluid. We though it was a leaky brake cylinder so we replaced the front two (As one was suspect) and moved to the rear.
The rear didn't appear to be leaking at all but we thought we should do all four at the same time. It was at this point we noticed that the paint on the rim on the passenger had bubbled from heat, and we believe this may have been evaporating the brake fluid.
We then tried to remove the axle nut and that was a no go. We had so much lever that we started turning the engine over with the handbrake on (probably not the best adjustment I will admit) before we could break the thread.
The car sat for 6 weeks and we come to tonight. We heated the nut (and subsequently the hub) with a heat gun and tried to break the thread using a cold chisel. This didnt work so we gridded the nut until we could open it with the chisel.
At this point ignited brake dust fell out of the inside of the drum (from the grinding and heat gun). We looked at the inside and didnt see any purpley heat marks to imply the brakes were locking on. We also pulled the seals back and couldn't see any of these marks on the ball bearings either, they also appeared to be intact, there was blackening on the inside of the bearing seal that slipped around the ball bearings where it was in contact with the axle. It's worth noting there was still a fair amount of oil on the bearing, even after sitting for 6 weeks.
So my dilemma is what is causing the heat? The brakes don't appear to be locking on and the wheel bearing doesn't look like it has collapsed at all.
My tendency is to think that when I last worked on the drum assembly, I have over tightened the axle nut and the tightness against the backing plate has caused the whole unit to heat up. (Possibly even igniting the brake dust and having that smoulder inside the drum as well. After all, we did ignite the dust just from the heat from the grinder and heat gun).
Has anyone else had a problem with the drum heating up? Does this sound like the culprit?
Thank you for reading,
John/Allbones
Allbones ·
