Aussieveedubbers · Bugs
Lowering front end of a 71 SB
https://forums.aussieveedubbers.com/threads/106310/lowering-front-end-of-a-71-sb
plimthing ·
Whats the best way ( cheap would be nice too) to lower the front end of my SB by about 2 inches?? Its sitting nice and low at the back but the front looks a bit too high for my liking. Would just like to lower it to level her out a bit, as its arse is sagging on the floor a bit.
barls ·
lowering struts mate are the best way.
depending on your rims i wouldnt go more than 2 inches as on 14 inches you will carve the inside of the rim out with the ball joint. 15s will hit occasionally.
it depends on what else you want to do.
if you want wider rims you need to run something like the smaller spring version like the vforce and topline.
if you want standard width go the adjust a drop ones.
lots of good info here
http://forums.aussieveedubbers.com/viewtopic.php?tid=48798&page=1
