someone has baja it so that will all have to go haha..
plans are replace front and rear apron areas as they have been cut out.
fit a golde roof section I have to it. get some parts its missing get the 36hp running and slamm it.
vw40hp ·
Very cool. I like the 58-59 with semaphores and small tail lights. They are cool. Cant wait to see some progress photos
beetle_nut ·
Few more pics of the old girl.
nils ·
Try to turn those big tyres with a 36hp would have been fun 😁
beetle_nut ·
Yeh they have to go.all the baja stuff is off now.early bonnet is on just need some early gaurds and a few other bits and pieces to get it to look like a beetle again.need some stock 15 inch bug rims and some tyres to roll it on..
beetle_nut ·
Starting to look like a bug again..
Dalyrics6 ·
Planning on a Full Resto? going to look amazing, keep us up to date!
beetle_nut ·
No not full resto.just rat.will take the paint back to the og grey underneath and thats about it.
thanks I will keep it updated. .
pete wood ·
Great plan. Fix it, rego it, drive it! 😏
beetle_nut ·
Few more pics.
63ragtop ·
need to drop that nose a little!
good score mate.
beetle_nut ·
Yeh the person I got the car off dropped the rear heaps..the front wont get done till im finished everything else..
il probably raise the rear just to work on the car then air bag it hopefully...
beetle_nut ·
I got the 36hp motor going today after sorting out the fuel tap leaking..next is the brakes..
beetle_nut ·
Bit of a up date.golde roof cut nearly done for it to fit in.a pillar repaires under way.brakes all done
also got a air bag beam from jer fab soon to on its way.
6inch air beam with bag.and also his rear kit to come aswell..
beetle_nut ·
Camo ·
Allways good to see an old girl coming back to life 👍
Will that front beam only be running one airbag?
Keep the photos coming 👍
Kev
beetle_nut ·
Thanks mate....
couldnt leave it as a baja damn....
and yeh it runs one bag off to the passenger side.and a different way the tie rods run from the steering box to the spindles..will post up as I go..
Thanks again. : )
LUFTMEISTER ·
I hope you specified RHD as the beam looks like a left hooker. 😵💫
beetle_nut ·
Thats not my beam just a pic of what they look like..il definitely be getting a rhd one mate hahahaa...
beetle_nut ·
beetle_nut ·
Bit more work done on the bug.repairing the deck lid and added some vents for the vert look.and my 6inch air bag beam is done should be shipped out to me soon...
beetle_nut ·
Also got some bits today.
got a og flash trim.and a og early horn button and rear view mirror with sun visor.
beetle_nut ·
My air beam arrived today...
beetle_nut ·
Also I got some panel beating hammers and dollys.i got the rear end clip welded in I just have to dit the early rear apron.and I got a nos l/h 1/4 panel to replace my crappy one.getting their slowly..
waveman1500 ·
Nice project, looks good.
Have you spoken to an engineer about getting the suspension complianced?
I would be really surprised if the Jer-Fab air beam could be made legal in Australia. It looks like it is made from steel plate welded to an original trailing arm, which is generally a big no-no for engineering compliance.
beetle_nut ·
Ok thanks.
im aware air bag suspension is not legal..
Paul Smith ·
Where did you buy the quarter? I need one to suit "63" for the other side.
LUFTMEISTER ·
Panel is New Old Stock factory panel. You can buy them at the unicorn farm. 😁
scoopsta ·
just finished putting in a front quarter for my oval.
that quarter panel doesn't look like a pre 60 one. will it pose a problem for the fuel tank?
paul try vicsbahn he might have a nos one for your 63
beetle_nut ·
I got the 1/4 panel off the very nice man that posted under you.
luftmeister..he saved my ass with that panel.
and il make it work and look as it should when I fit it...
can use the fuel tank surround off my early one if need be..
beetle_nut ·
Beam is in and is well under 1/2 inch off the ground maybe abit less.
and the cross over steering set up...
oldturtle22 ·
Looks awesome, any progress?
beetle_nut ·
Iv just been working on the rear end moving the tin up for the tranny raise im going to do fixing any rust on the rear cut I put it plus any repaires I need to do on the early rear apron.i have to go through and finish each part at a time rather than do bits here and there.so im going to do the rear and then move to the front of the car..more pics up soon..
beetle_nut ·
Couple of pics to put up.
trans raise done jus have to weld the mid mount to the fram horn area.
put my flappers onto my rims
and a pic of the rear side sections all welded on.
beetle_nut ·
Put a gew parts on today jus so it looks like a car for abit.
rusty69 ·
That stance is just so nice... looks like it has a nice rake too.
pete wood ·
beetle_nut wrote:Beam is in and is well under 1/2 inch off the ground maybe abit less.
Narrowed beams and airbags are not my cup of tea true enough, but I can see what people are trying to do with them. However, the construction of that crossover setup makes me really nervous. The way the driver's tie rod end goes straight through your main tie rod without any bracing... I reckon it's asking for trouble at some stage. I'd be doing some designs and talking to a few mates about how you might brace it a little. 😉
LUFTMEISTER ·
Looks nice. Any headlight issues??
h ·
beetle_nut ·
The tie rod arm is solid where the tie rod goes through .
and yeh head light hits on full drop iam doin a pan head shorten of a inch which will solve the problem tho...
empi ·
Shorten the headlight bucket
beetle_nut ·
I want to bring the wheels back as on full drop they sit to far forward.
beetle_nut ·
Notched the spring plates out today to get the car lower in the rear to see how it should sit when bagged.also put my side trim on and aussie flash trim aswell with sticky tape.jus so I could see it looking more like a car for a couple days before I get back into the body work..
joesbuell ·
Looking good. Keep up the good work 😉
beetle_nut ·
Thanks mate appreciate it.still heaps of work to go on this car.but im doin my best to get it all done properly.
Paul Smith ·
As was suggested on page 1 I got on to Vinko at Vicsbahn and now have a quarter from a 58 which I will have to mod a bit to fit my 63.
beetle_nut ·
Good score mate.better than a rusted one you have to spend hours on to fix.il be fitting mine soon...
beetle_nut ·
Been plugin away on this slowly.
have pulled the front left 1/4 panel off to replace it and repaire behind it also doing the a pillar and the r/h front 1/4 panel where tje a pillar meets the 1/4.
re did the trans raise higher too.
My oil bath air cleaner wouldnt fit so I used a kombi one to keep the og weathered look.
oldturtle22 ·
How are you going with this James?
beetle_nut ·
Yeh ok mate.havnt done much lately as im waiting on a complete front cut for it.its gettin posted up tomorrow so once I get that il finish the front end and move onto afew smaller bits then take the body off the pan to do the floor raise and pan head shorten.then sand it all back to the og grey and colour match the repaires.gettin their slowly.
beetle_nut ·
I cut the front section today so i can start to fit the front cut i got afew weeks ago.just abit of trimming and should be good to go.
beetle_nut ·
Not to much to up date.have been in and out of court trying to keep my 3 kids i have full time and their mother is trying to get em back.
Iv tacked the early complete front clip in alot of lining it up properly with gaurds bonnet and tank in.also picked up another 36er.guy said it had a rebuild and never fitted.pulled a head off and damn this thing os clean inside..yayyy.
psimitar ·
Looking good 🙂
I've a 59 shell on a 63 pan that was in surprisingly good condition metal wise but my 56 Oval needed more work than your 58. I do love the semaphore bugs though 🙂
On your engine I think ye may need new barrels as the right hand one seems to have some pitting where oil and water have sat and had a little party. Shame if the pistons are in good nick 🙁
beetle_nut ·
Only paid 30 for the motor so no bigy.its never ending on this one.once its done im sure il get another one haha.sucker for punishment.am gonna pull the motor down anyway plus the 36er in the car is a runner aswell...
joesbuell ·
Very Cool 😎
vwsteve ·
holy crap, you must love welding mate!
beetle_nut ·
Hahaha dont mind the welding mate.its the grinding that sucks hahaha....
psimitar ·
beetle_nut wrote:Hahaha dont mind the welding mate.its the grinding that sucks hahaha....
Same here. Love welding but hate grinding. Me thinks anyone who likes grinding is a little odd in the head 🤪
beetle_nut ·
Yeh grinding is a pain in the ass.and iv got heaps of it to do.
Im going to be 🤪 by the time im done.
Hahahaaaa....
psimitar ·
yea, i'm terrible at leaving it as one of the last jobs by which time there's so much it's just plain frustrating. 🙂
beetle_nut ·
Exactly what i have done
Haha.
Once the front cut is all on im going to go through and do it all.
I so will.😂
psimitar ·
😂 Yup, I've left bit's on the interior undressed cos with underlay etc ontop it really don't matter plus keeps strength in the weld. Yea, that's what I tell myself 🙂
beetle_nut ·
I wish i could jjust leave them.
But i have to hit the welds back or they will just haunt me dor ever.i cant leave them not nice looking.even tho i hate grinding that much hahahaaaaa....
beetle_nut ·
My rear air bag set up turned up the other day
Cant wait to get it bolted up and in the car.
Smiley ·
Very cool. Can't wait to see it bolted on the car.
Smiley 🙂
oldturtle22 ·
Massive like!!!!!👍👍👍
beetle_nut ·
Thanks mate.its all in now aswell jus gotta make a couple adjustments and im in slam town.
Lovin the set uo for sure.
adlbeetle66 ·
Coolio... looking forward to seeing it even lower...👍
beetle_nut ·
If it wasnt pissin down today id be done.
Rain rain rain.
beetle_nut ·
Took afew pics the other day.she does go lower than this and still plenty of work to go.
psimitar ·
Totally slammed man 🙂
Is that the ragtop roof I welded in? If so it looks nice 🙂
beetle_nut ·
Nah mate totally different car i do all my own welding now.i put this goldie in plus another in a mates car aswell.
psimitar ·
Cool. Nicely done too 😉
beetle_nut ·
Thanks mate.did it a different way on this and my mates car than how i cut it out and went on the other car.prefer this method alot more.thats no panel beating or filler to that instal yet either...
