Yep, me too. I'm over the twin Webers and FK87s, I'd rather have something that pulls off idle to make it easier to get off the mark with the dragbike in the trailer behind it!
This is just me personally though, each to their own. I still like 7000rpm and big ugly spitting carbs, just not every day.
I'm just building a new motor for what I want now, based around highway revs of 3000-3300, towing torque for that little light trailer, and generally being smooth and (*sigh* Jeez I'm getting old!) ........ pleasant.
This recipe never fails, you might like it too..........
Stock cam with 1.4s, or a cam with intake duration less than 230*@.050" or so if you're already going in (more WILL reduce bottom end). Norris 352 or 329, CB "cheater", this Schneider .......
http://schneidercams.com/131Fvolkstype1.aspx
Stock Solex 34 or small Stromberg 1BBL on centrebranch.
Any exhaust that you like the sound of best, and has intake heat if it gets cold at your place.
Stock heads with good valve seats and decent high-flow valves (like from CB or SI), maybe mild pocket port perhaps.
If you keep the stock .89/.93 4th gear and mix it with a stock 1.26 3rd gear (rather than the 1.36/1.41 3rd some like for dragracing), then IF you get some stooopid hills, or IF you are towing/carrying a bit of weight, you can kick it back to 3rd and still hold 90kph without revving it's tits off. Hhhmmm, funny how they might have thought of that when building a small underpowered car.
Capacity is whatever you already have, or are willing to go to, bigger is not always better. My latest new motor is going to be a 83mm bore with a 76mm crank, partly coz I have them in the shed, and partly coz if I don't use a big-bore kit then I can consider myself a rebel!
15km/L easily, probably 150kph (maybe, who cares?), 0-100 in under 10 secs, it's all good.
Enjoy.
