http://forums.aussieveedubbers.com/viewtopic.php?tid=85509
Have a read of my post its pretty long but may give you some help
NOW... I am getting to settings of the suspension and there a differences in what works. Here are two different suggestions comments would be great...
__________________________
FRONT
Discs all round YES
2 Castor shims per side YES
Extra camber adjustor BENT TOP TRAILING ARMS
Anti RB for lowered car
Adjustable shocks set half way
Bridgestone RE720 185/50/15” Tyres NONE YET
Set toe at ride height to ½ deg toe in NOT SET YET
REAR
Discs all round YES
Z-bar adjusted to be “on” full time, not Camber compensator CONVERTED TO IRS
Bridgestone RE720 185/50/15 NONE YET
FRONT
Swayaway adjuster top and bottom YES
2 super eccentric camber adjusters YES
-2 degrees negative camber HOPING FOR UP TO -4*
3-5 degrees castor
5mm toe out (6/32 – 7/32”)
18mm (3/4”) Sway bar
195/60/14” tyres PROB GOING 195 OR 205 X 50X15
Front 1” higher than rear? WENT FOR 28MM REAR T BARS INSTEAD
Cofab/ KYB gas shocks
REAR
Sway away camber compensator IRS
Cofab/ KYB Gas shocks
-2 degrees Camber
2-3mm (3/32 – 1/8”) Toe in
205/60/14 tyres
Shimmed up Z bar
1’ lower than front
Brakes????
Car I fit front callipers to the rear as well and have a proportioning valve to bring the bias into play. Nothing worse than having brakes lock up at the front while the car isn’t actually slowing down (recommendations here for handbrake or options otherwise braking great!) PROB LOOKING AT RE BONDING NEW PAD MATERIAL GREEN STUFF OR SIMILAR
So hopefully you can see where I am heading and I would love advice from numerous people in the know please. I also read somewhere about polyurethane boots on the front suspension??? NO
Also as I said above I want to separate the pan get it blasted and powder coated and then commit as many improvements as I can so I have a car that rolls and stops and handles well, anything I have missed would be great.
Thanks Aaron
