Hi Guys
I was reading about the Hoover mods the other day and got to pondering.
It seems that one of the key aims is to increase the volume of oil going to the right hand head / rocker etc.
This is achieved by increasing hte oil flow to the right hand side of the case / lifters by extending the oil passage to the 3 cam bearing web.
This modification is highly dependent on the squareness of the original oil way(which I understand is a bit dogy in new cases).
So in thinking this through, if you wanted to increase the oil flow to the right hand side without the risk associated with extening the oil way to the no 3 cam bearing web, wouldnt it be easier to either:
1) Simply increase the size of the oil passage on the right hand side by say 0.5 mm. Would that not increase the oil flow to the lifters?
2) Rather than put a cross slit across the lifter so both portions of the lifter recess are active, simply machine the hump between the two chanels down a bit so at all times there was poitive oil pressure to the push rods (and between lifters)
Just kicking it out there for discussion.
Newt
Newt ·
