RodPenrose ·
I have found this turbo kit here that I purchased on one of my US trips a few years back . The header is ceramic coated , is to suit a stock width engine , has a T3 sized turbo with a polished compressor housing , ceramic exhaust housing , a Deltagate mk2 wastegate with a dial a boost controller , complete inlet manifold to suit either Super flow or Comp eliminators , has electronic injectors and fuel rails , has a 50 mm throttle body with TPS installed , air temp sensor and will work with the stock cooling tin . The turbo is mounted 250 mm behind the front pulley and the wastegate is 400 mm from the pulley . This is located in Wollongong NSW and I would like $ 800 for this complete kit . I can also supply you with a new or reco set of heads to suit , ROD , 02-42729920 .
