Hey all,
Another bug up for parts! This one has some real goodies!
•Prices - listed below
•Location - Sydney, Concord 2137
•REGO - Yes
•Contact details – Nathan Hearn 0415 SEVEN TWO SIX 245 or Alex Holzl 0415 Two Nine Two 220
DETAILS
(Package one) $3500 or near offer
BODY/CHASSIS/wheels and brakes (no motor, geabox and etc)
The body is in average condition, needs rust repairs to rear pillars. The body will come with suspension and brakes etc.
-Firewall moved forward
-Late rear apron EFI
-Late a/c front apron
-Sparco race seat with OMP harness.
-Spare standard seat
-Momo Steering wheel
-x4 aero guards 2x spare rear guards (one rear guard on car damaged)
-Porsche headlights
-Whale tail with brake light
-stock boot lid with 1303ls badge
-VDO Large tacho pro eliminator
-VDO oil pressure guage
-VDO oil temp guage
CHASSIS
-Braided fuel line
-T handle short shifter
-Berg gearbox mount; engine and gearbox 35mm forwards
-28mm torsion bars
-bilstein rear shocks
-Powder coated front struts with koni adjustable shocks
-944 rear trailing arms
-Eibach springs with helper springs
-Poly bush kit, front and rear
-Front Boxster 3.2 brakes
-Rear 944/964 alloy callipers with mechanical handbrake. (handbrake not connected yet)
-Clutch tube; additional support added
-Fork stiffening
-Gell Cell battery
WHEELS
-17x7 and 17x9 Porsche wheels genuine
-215/17 Front and 235/17 Rear Federal 595 RSR street/race rubber good tread
(Package 2) $7900 ONO
COMPLETE RUNNING ENGINE (everything you need to make this engine work in your car)
-150hp at the wheels
-1500ks since rebuild
-Type 4 2700cc Dry sumped
-Case Chemically cleaned
-Okrasa Counterweighted crank dowled
-lightened flywheel with Kennedy 3000lbs clutch
-Auto Craft 3stage oil pump (with braided lines)
-Clyde berg 51.5mm IDA Webbers with match ported manifolds
-105mm pistons and barrels (will get brand asap)
-All braided lines and earls fittings
-Dry sump tank
-Solenoid shut off valve for when parked (stops oil filling motor)
-oil breather tank
-cleanable billet oil filter (spare complete unit)
-RX7 cooler and braided line
-Hand made extractors (need recoating)
- Porsche Fan setup
-Rocker cover breathers
-has 009 distributor as previous ignition system packed up.
-Comes with spare spark plug leads
HEADS
-Genuine type 4 square port factory cylinder heads
-Welded and relocated spark plug hole
-Big valves 50mm inlet and 38mm exhaust
-Manley extreme duty stainless valves
-Reshaped chambers
-Cylinder heads glass blasted
-Fly cut to 105 barrels
-Chev offset valve collets
-VW/Porsche 914/1700 Rockers with 911 Porsche swivel feet tappet adjusters
-Berg T2 Moly rocker studs
-Chev triple valve springs
-Chev Chrome Moly retainers
Im pretty sure ive got everything here, but pretty much anything that is needed to run engine is included.
GEARBOX SOLD
(super strong gearbox suit circuit car or street car with big engine)
-Custom ratios 1st, 2nd, 3rd, 4th (All Albins Gears)
-New bearing
-New hosuing
-quaife diff
-extra Tall 1st and 2nd (like a 5 speed without first)
-T2 flanges
-T2 (kombi) drive shafts, CV joints, boots and axels (strong)
-High Torque starter motor
Alex Holzl ·
