Hi guys
I have a problem with my fuel sender and after some diagnositic mucking around, it appears that the sender is not working correctly even though it is only about 12 months old.
The faulty unit is a "tube style" sender that I purchased from Classic Vee Dub about 12 month ago as the it was the same type that it was replacing.
To cut a long story short, I've tested it with an OHM meter and it reads inconsistently. (10 ohms full, 73 ohms empty). On the bench, I could get it to work 99% of the time but when I installed it with the OHM meter attached, it kept reading empty (73 ohms). I had a feeling that the float was not "floating" so pulled off the tube and installed the bare skeleton and the float didn't "float"!
Any, my question is, what is the correct sender unit, the "arm and float" or the tube type?
And I assume that the float arm (if the correct type is the "arm float") points to the rear of the car?
Thanks for your help.
Regards
Greg
Lateral ·
