donovan wrote:when changing from 2nd to 3rd, my auto 72 squareback motor doesn't back off like it does when changing from 1st to 2nd. gears change ok but it revs like crazy. I have lived with it for a while. just wondering what the problem might be and if it was an easy or expensive fix?
Not sure if I understand your problem, it changes fine from 1-2 ok..and then 2-3 it changes ok (firm),, or does it slip (rev)??
If you mean it the engines revs dont drop (keep revving) on the 2-3rd change, it sounds like the D/R clutches are burnt, and you will lose reverse soon too. Smell the oil to see if it smells burnt.
If so its time for a rebuild as the clutches don't usually burn out by them selves the auto has been to hot or there's a hydraulic issue, old pistons, seals. ect.
Aaron
