x275 wrote:The ball on the end of my shifter has no pin..
There is a small amount of side to side movement where the hockey stick connects to the billet coupler.. It sounds as if the rattle is coming from up front but it could be travelling down. I'll start at the back again and recheck everything.
Cheers.
If the angle on the end of the couplers grub screw doesn't match that of the angle of the locating hole in the hockey stick then you won't get very positive grip between the screw and hole. If the coupler to hockeystick fit isn't very snug then you'll get slop.
I had this problem with an incorrectly profiled grub screw before.
As for the gearstick BJ. I remember those I've adjusted having a pin at the front of the ball that fit's into a slot in the socket. Maybe it was a later design to help with side to side movement of the shifter rod.
