Just putting it out there if anyone has a VW Grundig ECU 1218 Tester (as pictured) that I may use, borrow, purchase to run some tests on the ECU on my '68 Type 3 Square.
Craig
southspark ·
Hi Craig
No tester but somewhere amongst my technical book collection I have info on the early sistems,what is the problem with your ECU?
Paul
VWMA Editor ·
Hi Paul,
An enrichment issue on cold start. I have all the books and manuals and I've been playing with a few different temp senders, MAFs, etc, but the tester would just help to determine any wiring or ECU faults.
It appears tonight I may have found one to borrow, so looking forward to plugging it into my Square.
Craig
southspark ·
Is running lean or rich on cold start ? If lean do not neglect vacuum leaks.
