Aussieveedubbers 路 Tech Talk
buying rebuild 36hp parts
https://forums.aussieveedubbers.com/threads/106913/buying-rebuild-36hp-parts
oldturtle22 路
Where do you buy decent 36hp rebuild parts? piston and barrel sets, gaskets, main and rod bearings....
I see Wolfsburg West has a fair range. Is this the only supplier though?
cheers in advance
psimitar 路
CIP1 and West Coast Metric show some of the major rebuild parts and I think Aircooled too but the main supplier is WW as they have many of the parts manufactured for themselves just like their window/door seals.
Unless your barrels n pistons are proper buggered then a hone and new rings will do the trick 馃檪
Cyl heads used single stepped collet 7mm stem valves so unless you can find local 7mm stem multi groove collet valves of the correct dia and length then again it's WW, same for the guides and collets.
vw54 路
VVDS in Sydney have most parts on the shelf
psimitar 路
vw54 wrote:VVDS in Sydney have most parts on the shelf
Yea, but they're mainly imported from WW right?
vw54 路
no not necessary they have some NOS items
psimitar 路
vw54 wrote:no not necessary they have some NOS items
Cool 馃檪
oldturtle22 路
Thanx for the help guys馃槑
