Wow it is amazing how someone can do such a thing to another person, especially someone that has the same love of vw's. The idea of having a site like this is to bring people with the same interest together, and so we can help out eachother however we can whether it's just some simple advise or whatever.
Hope things work out for you and your vw.
Cheers Matt
ocdrbug ·
I don't know the person previously mentioned personally so none of this comment should be taken or misinterpreted as referrance to his reputation. what I see is a engine that has had water siting in it for a short period, other than that the rest looks in reasonable order from the pics. It looks typical of an engine that's been degressed/ washed before installing. any engine that SITS unused for any period unusd will accumulate surface corrosion in the bores unless it is pre lubed and sealed with gladwrap from my experience as a biketech. After 8 months I would of expected to take the top half off for fresh rings & head gaskets anyway before in stalling. I'D be interested to know how much you paid for it as that in itself can tell the rest of us half the story. best bet is try sorting it out privately as its unfair to ask other ppl to judge someone else with only one side of the story. 😎
vwo60 ·
Same thing happened to me except i paid $2500 for a imaculate type three engine. it is a shame it is nothing like the add or his discription.
what is the end play like?
What cam and crank were in it?
was the clutch new?
Did you fire up the motor when you bought it? or at least turn it over? check the end play?
a new top end thrown in and there wouldnt be much left of $1,500
P&C's..... $400??
Heads ....$400??
@ $1,500 for clutch, long block and dizzy I would have to say its a lucky dip
Whatever... that is my opinion
Seems strange to have what appears to be water in an air cooled engine? I feel your pain, as I have had things happen in my life that have turned bad, all I can do is forge ahead and focus on any good things that come along.
Definately water is the major issue here, and an unsatisfied purchaser. Have you determined what the metal inside the cylinder is, that will be the tell tale as to what went wrong and whether the original seller had any idea of what was going wrong. Shame he hasn't come up with the promised paperwork, but sounds like a familiar story.
On a brighter note, if the end float and general condition of the bottom end seems reasonable, you could probably get away with cleaning things up, giving it a hone, some new rings and having the heads serviced. You will end up with a known engine that will give good service, mind you tho, you paid a premium price for a second hand engine, one would expect way better condition than an engine that has been full of water.😠😠
pfillery ·
I'm inclined to agree with bizarre.
Was it purchased as a runner? Did you run it, check it, pull the heads off? If it was only a short motor you really are taking a punt.
No disrespect to you as the buyer but if you have had it sitting for 9 months and were uncertain of the condition at the time of purchase, what can you do? If it was degreased for sale especially if it was done minus carbs or manifold, then subsequently not run it would be likely to have gotten wet inside.
Surely finding a good running engine for an early beetle with a $1500 budget would give you a lot of options. Especially given that you weren't after originality. You can often pick up a whole donor car with running engine for less than half that. You would have been up for carbs, tinware, all the other bits too.
I can understand your frustration but see it from the sellers point of view too. It's been nearly a year.
lohoon ·
We understand your frustration. Hope your missus is doing well. Clean the heads,lap the valves,hone the barrells, clean the pistons. Most of this stuff is a little bit of your time. It'll be fun,and you get tell everyone you freshened up the top end. The super cheap hand held sandblasting gun works a treat on heads if you've got a compressor.
fish26 ·
Boomer, you definitely have your priorities right and I hope your partner is now healthy and free of that f#%$^$^& up disease.
I can offer you four used cylinders and three pistons, the fourth was kissed by a rogue valve head, your heads may clean up fine and only need a valve job and new springs.
I don't know who sold you the engine and can only offer you my help.
vwo60 ·
I see no care taken when the engine was in the sellers hands after he has been paid, as i stated i paid him $2500 for a type three engine with 39,000 miles on the clock,with NOS fuel injection spares which was advertised on the forum as a perfect engine , the same seller told me it was ready to install, paid him in good faith on the 28th of Feb and recieved the engine on about the 30th of July, repeated emails for him to sent it was meet with excuses, when it turned up it was dropped a three hour drive from home at a truck stop, the engine had been left open since removed from the car, type three dip stick tube, exhaust ports, the clown had broken of a rear exhaust stud removing my heater boxes then procedded to butcher the gasket face with a hack saw while still leaving the broken stud in place, replaced all the standard tin with damaged and modified tin, also forgot to tell me the case was painted red and the generator supplied is no good,, as the engine has been left in the open and i am not realy interested in spendind more money on an engine i have every right to expect to be as discribed, both by the seller verbally and in his add, i have sought legal advice, i have had an oil sample taken and have the engine with a qualified automotive engineer for accessment, i will be seaking legal redress with the individual for the return of my money and any legal costs i incurr, do not defend people like this as it is not good for our hobby, anybody interested you can email me and i will tell you who the seller is so you can avoid them in future. PS, as of today i have not received any of the parts that were supposed to come with the engine, the seller had kept them because i had not paid the truck driver, he did not know that i had sent him a bank cheque, another email promising to send them, have not arrived as of yet. will keep you posted. My ownly mistake was to be trusting,
reub ·
Sorry to read... Seems to be the way buying second hand stuff sadly unless thoroughly inspected prior.
Very sad day when you cannot trust another vdubber and a sad reflection on the person involved, just been PM'd by another victim.
HappyDaze ·
Although it it is starting to sound like a bad idea to be buying engines on here, I should point out it can be the opposite. Not all the apples are bad.
A while back, I bought a 2276 engine [advertised on this forum] from Ben Robinson. Ben described the engine to me, and it sounded like what I wanted for No. 8 Beetle. A quick check with Rod Penrose, and all looked good. All I had to do was fit a good ign., and smaller chokes to the 48 IDAs, and it ran [and is still running] beatifully.
Just saying not everyone is out to dud you.🙅
Hope the outcome for your good lady is a good one.👍
BOOMERDOG ·
seller has now paid for a new piston & barrels...thanks for all replies on this subject...
admin if you want to remove this thread.. go for it..thanks..boomer
vwo60 ·
I want to leave the thread open, people have a right to know, if you hasd not posted you would have not got the new barrels and pistons. happydaze iot is good you got a good buy.
Governor ·
As above and I would not have removed all your posts either!
How does that help others who might be cosidering purchasing from that seller.
Or was it conditional that he would only buy you the parts if you removed your posts??
scot70wagon ·
No pressure has been applied to anyone. For those whose life will cease to end if they dont know all about other peoples business my number will be forwarded to them by pm after they contact me and they can discuss any issues directly with me.
vwo60 ·
Scot i am glad you replied, You are right Scot, there was no pressure to buy the engine from you, but it was bought both on you written and verbale discription. Perhaps Scot you could explain on the forum why my engine was not sent as agreed, paid on the 28th of Febuary, dropped in a truck shipping yard three hour from home on 30th of July after emailing you each time i was comming home from work, only to be given some lame excuse as to why you could not send it, type three dipstick tube not even taped up, all the exhaust ports open to the elements, broken exhaust stud with a butched gasket face, non standard tin ware, worn out gererator, my extra parts with held because you thought i did pay the freight when i did, your discription was, you will be able to fit it straight into your car with no other work and that is why i paid $2500 for engine which in reality is valued at $800.00. well it looks like i will have to disassemble the engine because the engine has been open the the elements with water ingress, please feel free to reply on this forum so no one has to contact you , as i have suggested to you , just refund my $2500 and we are all square with both of us wiser for our experence.
scot70wagon ·
Like I said you have my number. Please feel free to call me. I am more then happy to discuss it with you.
vwo60 ·
I would be wasting my time as you have already stated that it was just a second hand engine and you would not give me my money back, answer the questions i posted above on an open forum and also answer how you would feel if it happened to you in your reply, thanks for replying so at least people know who i was refering to.
esevwbits ·
i've bought plenty of parts of Scot in the past, never had an issue. buying second hand is never guaranteed! i know i'd trust scotty and if it was a dud, it wouldn't be intentional.
kaiisons ·
touch wood, I have an engine from scot - secondhand and it went up to valla and back. i know my mate has two s/h engines off scot and they are running well too.
BOOMERDOG ·
yeah well...update on this..the block was totally stripped by a professional engine builder,the so called '1835cc' turned out to be a 1641cc,top end was shot..including heads, bottom end revealed totally stock, no performance cam as proclaimed, oil pump drive was on the end of the cam was virtually sheared including the end of the oil pump, the crankshaft bearings were shot, the case had been lined bored once..& definitely needed doing again... the other bearings were all done, either high miles or driven really hard..plus the oil pick up tube in the sump was actually floating around loose in the sump!..wtf!
so all in I think I have got about $200 in salvageable parts from
the engine...even thought the seller paid for new pistons & barrels after all this was brought up I needed to check the bottom end of the engine as well... I am stil $1050 out of pocket.. contacted the seller..he is pretending it aint happening..i am very fucking pissed off..
let this be a warning to all potential buyers....I will not be so trusting to buy second hand... ...vw owners should not do this sort of thing to other long term enthusiasts..
wrong on all levels...
vwo60 ·
The seller decieded to deposit $500 into my bank account withuot my concent for the parts that i had paid for, his valuation, seeing i owned them and paid for them in Febuary this made me rather angry, another email with the threat of legal action which i was prepaired to carry out resalted in another $1200 in my bank with the condition the the balance would be forth coming when he received the engine back, fat chance of that, untrustworthy to the extreme and would advise all concerned to steer well away from the individual, I still have the engine and it has cost me $800 and is probably worth it, nothing like being guilty by admittion.
BOOMERDOG ·
Probably the worst mistake I ever made on this forum.
Just a bit of an update, finally got around to starting work on the engine today and drain the oil, remember this engine was sold to me with 43000 KLM on the clock and ready to fit to my car with no further work required, make your own mind up. lucky I have it down to $800 as I am going to have to overhaul it .
karmann141 ·
NASTY!!!
Luckily you got some $ back from the initial price of $2,500.
Hopefully the engine is still OK - $800 is still too much if it's a dud.
Hopefully a valuable lesson learned buying a second hand engine from this individual.🙅
So sad.....What about new engine suppliers that offer no warranty. Now there's another can-O-worms right there!!!!
Governor ·
Matt I can recommend a good engine builder. lol😜
BOOMERDOG ·
if I posted the pics of the inside of the bottom end of the block I got you would wince..seriously
...its that bad..it's that worn & its totally stock which was not what is was advertised as....pfft!!..it's beyond bull shit!
vwo60 ·
That all seems acceptable to the seller, I have had five emails form other people about dealings they have had from the same person. all similar.
BOOMERDOG ·
me too...
barls ·
Once again no naming and shaming as per forum policy. If you disagree take it up with the forum owner
I have pm'd Ernie with our views
roverv8bay ·
Good evening. I apologise for any problems my comment may have aroused within the forum. Will keep my thoughts to myself from now on.
ernie
vwo60 ·
HI barls , if you care to read the post fully you will see the person concerned has already named himself without anybody else committing that crime. could not help justifying his actions.
BOOMERDOG ·
I find it leaves a very sour taste in my mouth he has taken advantage of many long standing enthusiasts. ...taking a crap on your own doorstep doesn't stand you in very good stead now alot of other people who have had dealings are now exchanging experiences. ....embarrassed/ashamed are just 2 things you should be...
karmann141 ·
As previously said by vwo60 – as Scot (scot70wagon) has responded to the post, without anyone naming him, he has given up his right to anonymity.
The VW fraternity is a relatively small community with many of good people sharing the same love for VW’s, most of who would go to great lengths to help out a fellow veedubber for no monetary gain.
Therefore it’s really disappointing to see a longstanding member of the vw community blatantly ripping off his fellow members. This is not a one off mistake, as vwo60 has been contacted by at least 5 other veedubbers with similar stories of dealing with Scot and including Boomerdog, that’s 7 we know of.
This is a very sad indictment of this individual’s character – as the saying goes “Don’t Shit where you Eat”.
Not all of us are flush with cash – So come Scott – man up and do the right thing - return Boomerdog’s money (I’m sure he’ll happily return the engine and parts).
Try and restore some of your cred.
Boomerdog – shame you can’t reinstate your initial post you deleted.
(I hope this post isn’t deleted or edited – people need to know)
BOOMERDOG ·
#Ok so this was the original post from a while ago so everyone can see..i will post pics later of the bottom end…#, the seller did refund me $450 for new pistons & barrels after the initial post, but am still out of pocket $1050...anyone want a free boat anchor? ...the block is well thrashed...& needs a complete line bore/cam/oil pump/bearings etc etc..this was a stock motor with 1641 barrels..not as advertised as an 1835 with 110 cam etc...
so here it is...
After buying an engine advertised as an 1835cc which apparently' had proved itself' from s.........n last December for my 54' oval, I finally got round to starting the build on it, the engine has been sitting since that time in a dry garage under a cover due to finances being tight due to my partner falling victim to breast cancer, its been a long tough battle so have been doing it tough, this was an engine I thought I could finally afford.....
after bolting the engine up in the car I put on the new front pulley & revolved the engine on the pulley nut, things did not sound right at all.
so unbolted the engine & investigated further...
I dropped the heads off to my amazement I had lumps of metal fall out of no1 cylinder with sludge etc..the head was pitted to shithouse due to the debris that had been flying around in there.
all the other cylinders were shot, scoring,blueing ,the rings had gone on one of the cylinders ,as it was pulling oil from the block & you can see the clean burn of the oil on top of the piston...
receipts for the engine which was 'promised' to me never appeared.
the seller now really just dosn't want to know, I'm left with an engine that is shot from the start this just sucks that a fellow vw enthusiast does this to another.
I've been involved with vee dubs since 1984 & I can honestly say this is the worst I have seen
I have asked for my money back..no dice, apparently he has been trying to source pistons from his mates..what is stopping him from doing the right thing & either giving me my money back or at least offering to buy me a new top end..??
completely gutted....wrong on all levels ..talk about being taken for a ride..
see what you guys make of the pics..😠
Allbones ·
Do you have the initial advertisement and proof that it was adtvertised falsely?
While bashing someone on a forum is all well and good, youre not going to achieve the outcome you want.
My advice is take old mate to small claims court, get all of your money back, and charge him the additional costs of investigation with the engine builder and the like.
Just my 2c, might achieve abit more and put the wind up him.
LUFTMEISTER ·
Yes. Small claims would be your best avenue. Easy filing of claims up to $5000. Once you get a ruling ( should be easy as all the evidence is on this forum) He either pays you or you file a registered debt against him and it turns his credit rating to mud. My2c
Don't get angry - Get even.
BOOMERDOG ·
like I said...
I THINK ITS TIME FOR THE NAME BASHING TO CEASE. anything i have sold is sold the way i buy it, as is with no warranties implied or given as is the way with second hand goods. Boomerdog and vw060 you werent happy with the deal you entered into under these terms and asked for compensation. BOTH of you have been given money back and thats the end of it. Engines bought if they are ok they get sold on.With any vw engine it is impossible to check the size of the engine so you rely on the person who you bought it off to get the details of what it is or isnt.i sell them as i buy them, listing is as told to me. I have not shyed away and tried to hide as implied and have named myself when i didn,t have to so for manning up and restoring my cred for all the supposed horror stories that are out there there are a shit load more people i have gone over and above to help within the vw community. Everyone has an opinion and they have the right to exercise that opinion , but the name calling needs to cease NOW.
BOOMERDOG ·
no name calling..just telling the truth .....YOU didn't...
not 1835cc
line bore city..
torn oil pump drive
definitely not an engle 120..its stock..
mmm
vwo60 ·
Check out the state of the 43000 KLM engine you sold me as needed no work just fit into your car, is that how the engine was treated before you sold it to me, I do not think it has had an oil change for years, it is not about name bashing it is about letting people know who to avoid. particial refund or not , it is the process and the miss leading description of the engine and the five months you took to send it to truck yard that was a 3 hour drive from my home and dumping it there, the refunding of money without my consent for parts that I already owned, have a good look at how you have behaved in these matters, and all I did was to trust you with $2500 for an engine that is immaculate other wise I would not have consider paying that much for a type three engine, an apology to all concerned from you would go a long way towards making this go away, as for sending the engine back to you and then you refunding the balance, I do not think I would take that chance.
