Just need some guidance and help on how to grind out my gearbox!!
I'm putting a later model 1776 engine in my 1966 Beetle (standard - 1300).
I need as much help as i can get!!
I don't want to grind too far!!
Plenty of people have done it...
hellbugged ·
Just put the engine in and turn it over by hand at the pulley with a bar and socket as you tighten up the four bolts gradually. (Keep it square to the box)
The teeth on the flywheel will cut it easy.
Once the bolts have gone tight, remove engine and grind a little more off for clearance.
I've been told thats a dodgy way of doing it, but if you have done it?
hellbugged ·
It's the most accurate cause it's cut with what's going in there.
It actually cuts it with a very nice finish
Yep done it too many times
adlbeetle66 ·
Ok. Thanks for the help.
I'll probably post pics when done...
hellbugged ·
Yeah post pics, always nice to hear the end results...forum needs more of that
be easiest to turn over if you took the spark plugs out
Just take care near the starter bush. You will need to source an "adapter" bush to run a 12 volt starter in there too
Check your pressure plate is correct for the early thrust bearing as well
Change the input shaft seal if it needs doing while the engine is out too
adlbeetle66 ·
Done the bush. The starter motor is in. The problem now is what to do with the 6V cold start relay...
Do you care if i post pics of the inside of my gearbox, and the pressure plate and get you to see if it will match??
You obviously have the experience...!!!
coletrickle ·
or you can use a factory vw 180mm 12v flywheel,,You may need to look at getting a custom 180mm pressure plate if you plan on making decent power.I've got quite a few if you want to go that route and can't find one local,cheers
hellbugged ·
Ha hah was wondering if you still had them in stock col
pics are great!
adlbeetle66 ·
Col, is it the flywheels or pressure plates you have?
coletrickle ·
adlbeetle66 wrote:The flywheels or the pressure plates?
flywheels,they came on the 71?and later 1300std bugs,what yours had orinally,and use a1200/40horse pp and disc but depending on the box you may need to fit a running ring to the pp if its a lage box/throwout bearing.
adlbeetle66 ·
But is that gonna suit my 12 v starter?
Because i have a 6 volt engine that i took out, but i cant use that flywheel because ive now converted to 12v, and the teeth spacing is different...
vlad01 ·
hellbugged wrote:It's the most accurate cause it's cut with what's going in there.
Thats how i did it with no internet or any vw resources back in the day. Worked a treat!
adlbeetle66 ·
hellbugged wrote:Just put the engine in and turn it over by hand at the pulley with a bar and socket as you tighten up the four bolts gradually. (Keep it square to the box)
What do you grind it out further with?
Anything else you have to be aware of?
(shaft, T O bearing)
the 70s 1300 flywheels with 180mm clutch just use regular 12 volt ring gear.
How come you're sticking with the 1200/1300 gearbox?
that is going to be awful on the highway with a 1776 and doing those sort of revs you if you have your original non vented decklid you are going to get heat issues, (stand offs or holes behind the number plate fix that)
If you have a hard start relay you can just swap it out for a 12 volt relay, any 30-40amp relay will do the job.
hellbugged ·
Carbide burr or emery flapper wheel
Check your engine mounts too, change them if need be.
I think what col has would be an oring centre flywheel (so suit your later crank) with 180mm clutch but 6volt ring gear.
Anyhow, you've hot the hang of posting pics, so add them to here or your members ridè thread as you go
adlbeetle66 ·
Here is my flywheel...
I have a 12 v starter, and my whole car is now 12 v.
hellbugged ·
Cool
Any pics of the pressure plate you are going to use?
adlbeetle66 ·
Here...
hellbugged ·
Yeah ok
That's incorrect for your current thrust bearing. 🙁
You will need a center ring added to that pressure plate
And you need to check the crank and flywheel are compatible, you may have a 6 volt crank that will require a machining mod to the crank.
adlbeetle66 ·
hellbugged wrote:Yeah ok
Thanks for that. Can you PM me or upload a pic of an example that i need to follow please?
Be careful with filings they can catch fire easily and they are magnesium so water wont put them out.
I fitted a 228 flywheel in to my late single side plate box years ago, it just nipped up when the motor was fully tightened after I thought I had done enough clearing, so I backed of the motor bolts and then started the motor and did the bolts up a bit at a time, rough but it worked.Steve
