Wanted: Pedal assembly bracket
https://forums.aussieveedubbers.com/threads/106972/wanted-pedal-assembly-bracket
Trendy ·
I am missing a component of my brake assembly: Specifically the item in the picture. But in words its the bracket and bolt that reinforces the pedal tube that goes into the tunnel. And is this piece critical to have. Where does one buys parts and if not who would like to sell me a few parts for my 60 bug.
Trendy ·
Are more like this
donn ·
So before I go ratting through my box of "STUFF", is it the piece on the end far left or the piece that looks a bit like a plate with a "U" shape cut out?
Trendy ·
A piece closest to your left foot on the clutch. It must hold the assembly in place before it goes into tunnel.... which would go all the way to the passenger side. There is also a bracket to hold it all together on the passenger side. I have that side. Please refer to picture again. Circle red.
donn ·
gotcha, I must have been posting while you were doing the second post. I'm off to the parts bin to check ----------------->>>
56oval resto ·
hi Trendy
Vic at Vicsbahn has this part available , NOS - $20 , Used - $10 + postage
give him a call 0428145889
hellbugged ·
What year is your beetle?
Unless it's a 67, your pictures are for later pedal assembly and from memory, the highlighted piece is not used on the earlier models. It will just have a rubber seal there that has 2 lugs that pop into the tunnel
I will check today
Trendy ·
maybe your . My bug is a 1960. It may just need that rubber part your on about. No big drama.
grumble ·
Daimo is right ,these weren't used on early bugs just a dust/noise sealing rubber.
