Does anyone know where to source these tricky little intake manifold nuts.
I thought CB Performance did them but can,t find a listing on their website.
Cheers Col
bat69 ·
Make your own. I use 14mm hex bar which is cut 40mm long and tapped on the inside
hulbyw ·
Gene Berg has some specialised manifold nuts. Uses US post as well so it doesn't cost the earth to ship them
Cheers......wayne
Now that is something I haven't seen before..
Maybe VW should have used these on Air cooled engines...
RodPenrose ·
Col , I have these barrel nuts in stock . I also have the good 11mm nuts along with either 6 point or 12 point aircraft nuts in 10mm flanged , ROD.
colin ·
Thanks Rod I,ll contact you prob via Larry.
Cheers Col
Some told me a good hint with the nuts, put a taper on the seating side and that way the manifold will always be in the same position relative head
